Radiator hot on top cool on bottom
Old 11-23-2013, 12:22 PM
elite180's Avatar
Default Radiator hot on top cool on bottom
I replaced radiator, thermostat, water pump, and belt in 2001 Jag S Type
Now it gets great heat in cabin, but after running a while will run a little hot, and cooling can runs on after car is shut off for a few min. Bottom rad hose is cool and top is hot also rad is not hot all across, one side cool other hot. What is going on. I tested the thermostat before putting in and it works. it is also new
Old 11-23-2013, 12:46 PM
manycars's Avatar
Did you bleed the air out when you refilled with coolant? If you have the car slightly upwards at the front, it works better I'm told.
Old 11-23-2013, 12:56 PM
elite180's Avatar
yes I did. I was wondering if the water pump was defective maybe
thanks
Old 11-23-2013, 01:53 PM
clubairth1's Avatar
Received 2,241 Likes on 1,769 Posts
Are you aware of the special bleed hose and valve up by the brake master cylinder?
Also give the car a few heat and cool cycles as I have found this helps with the final bleeding.
Old 11-23-2013, 04:11 PM
Received 2,255 Likes on 1,840 Posts
Coolant enters the radiator at the top and flows across exiting at the bottom on the opposite side. The air flowing through the rad core removes heat which is why the core is much cooler at the bottom. This is normal operation, look elsewhere for your problem if in fact you actually have one. How do you know the car is actually running hot?
1100me
07-24-2023 06:10 PM
GordoCatCar
01-02-2017 01:10 PM
TXJagR
06-20-2016 01:02 PM
Harry Dredge
10-07-2015 01:17 AM
1100me
09-07-2015 06:26 AM
Quick Reply: Radiator hot on top cool on bottom
