Radiator hot on top cool on bottom
Old Nov 23, 2013 | 12:22 PM
elite180's Avatar
Default Radiator hot on top cool on bottom
I replaced radiator, thermostat, water pump, and belt in 2001 Jag S Type
Now it gets great heat in cabin, but after running a while will run a little hot, and cooling can runs on after car is shut off for a few min. Bottom rad hose is cool and top is hot also rad is not hot all across, one side cool other hot. What is going on. I tested the thermostat before putting in and it works. it is also new
Old Nov 23, 2013 | 12:46 PM
manycars's Avatar
Did you bleed the air out when you refilled with coolant? If you have the car slightly upwards at the front, it works better I'm told.
Old Nov 23, 2013 | 12:56 PM
elite180's Avatar
yes I did. I was wondering if the water pump was defective maybe
thanks
Old Nov 23, 2013 | 01:53 PM
clubairth1's Avatar
Community Influencer
Are you aware of the special bleed hose and valve up by the brake master cylinder?
Also give the car a few heat and cool cycles as I have found this helps with the final bleeding.
Old Nov 23, 2013 | 04:11 PM
Mikey's Avatar
Coolant enters the radiator at the top and flows across exiting at the bottom on the opposite side. The air flowing through the rad core removes heat which is why the core is much cooler at the bottom. This is normal operation, look elsewhere for your problem if in fact you actually have one. How do you know the car is actually running hot?
Harry Dredge
Oct 4, 2024 05:37 PM
1100me
Jul 24, 2023 06:10 PM
GordoCatCar
Jan 2, 2017 01:10 PM
TXJagR
Jun 20, 2016 01:02 PM
1100me
Sep 7, 2015 06:26 AM
