Oxygen Sensor location
Old 01-09-2008, 06:38 AM
morales8416's Avatar
Default Oxygen Sensor location
Hows eveyone doing and happy new year,
i have 2002 xtype 3.0 and pulled the code PO0057 which is oxygen sensor low circuit. It states bank two sensor two. Which of the four oxygen sensors is this as i face the engine? front of engine sensors or rear sensors? left side or right side.
Old 01-09-2008, 08:42 AM
Default RE: Oxygen Sensor location
Does anyone have information on the Walker aftermarket O2 sensor? Do they work and improve performance or are you better off just buying a stock product?? Can someone put a diagram of all the O2 sensors and how many wires each one is too. Thanks.
$180.00 ouch!!! Does it work?????[/align][/align]2002-2005 Jaguar X-Type - Walker Products After Cat. Left Oxygen Sensor - 4 Wire [/align][/align]Part Number: 25024439[/align]OXYGEN SENSOR, 4 WIRE, DIRECT FIT REPLACEMENT PART, LEFT, AFTER CATALYTIC CONVERTER -- Improve Your Cars Engine Response, Gas Mileage And Lower Its Emissions When You Replace Its Tired Old Oxygen Sensor, Exceeds OEM Specifications And Test Requirements, Original Equipment Part # C2C1238
Old 01-09-2008, 06:05 PM
bank 2 is front of engine ..lower .. easiest one to change..
moxie (08-19-2014)
Old 01-10-2008, 08:41 AM
thanks that was it !! no more check engine light wooohooooo!!!!!
moxie (08-19-2014)
Old 01-10-2008, 11:04 AM
aquill1's Avatar
Ouch...what do the o2 sensors cost from jag directly?
Old 01-10-2008, 11:22 AM
i have 2002 xtype 3.0 primium package and it has 68,000 miles on it. from jag i have a buddy that works thier original price list is 180 each. I get a hook up ten over cost which is 140. Every little bit helps.
PS is is after the crazy curse of the xtype bad transmission gearbox failure. I was lucky and bought the extended warrenty which the total cost of the new transmission install was 5,200 dollars. i did not pay a dime. so be weary of little slips here and there thats all the warning i had. Then one day cruizing on the highway at 75 mph roms just went out and instument told me i had gearbox failure i was like no **** when the rpm's went to 5 thousand rpms. So we will see what happens next.
installed HID's yesterday unbelievable how easy it was
take care and this site is the best i seen glad i ran into it
Old 01-10-2008, 05:40 PM
they occasionally go
Old 01-10-2008, 07:41 PM
Received 9,005 Likes on 4,113 Posts
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
ORIGINAL: morales8416
Hey morales n welcome to the site mate.
Sounds like you had a few problems got them sorted under warranty and had a lucky escape.... Nice post.
Glad you like the forum and hope to see more of you
Jim
Old 12-16-2014, 11:04 PM
robert eagles's Avatar
location of oxygen sensors for 2001 jaguar s type v6 dual exhaust post picture location will help a lot bank 1 1-3 bank 2 4-6.
mrplow58
01-21-2024 05:53 AM
Steviedee1st
11-28-2023 06:32 PM
RoyLittle0
09-17-2015 01:05 PM
skadmiri1
09-09-2015 11:27 AM
KarimPA
09-03-2015 07:32 PM
Quick Reply: Oxygen Sensor location
