2004 2LTR Xtype Stuttering
Old 12-29-2008, 10:34 PM
Jeffre's Avatar
Default 2004 2LTR Xtype Stuttering
Hello I am new and have owned an Xtype for the past 3 years, lately I have had some issues come up that I need help with. I have just replaced the spark plugs and will be replacing the air filter as soon as one comes in. The car is idling rough when cold and is making a popping noise and if you cover the air intake you can feel a blow back when it makes this noise. Also when you first start driving and you have too sit at lights for a couple of min, when you drive off again it will not go past 2500 revs and missies badly. In a couple of minutes it will clear and start to accelerate smoothly again.
Thanks for any help
Old 12-30-2008, 04:06 AM
BuckMR2's Avatar
Default RE: 2004 2LTR Xtype Stuttering
Hi Jeffre and welcome to the forum.
Assuming ithas beenserviced at least as per the schedule and the air filter doesnt fix, have a look at this as it only takes a minute and common fault according to dealer.
Remove the 3 screws holding the engine plastic cover on, remove it and check this pipe....many split and a sturdier one is £5 from the dealer...
If that doesnt sort it maybe need to get codes read to pinpoint problem?
aussie x type (06-03-2013)
Old 12-30-2008, 05:27 AM
Jeffre's Avatar
Hello Buck
Thank you for the help this pipe is split and I shall contact the dealer tomorrow to get the part.
Thanks Again
Jeffre
Old 12-30-2008, 05:32 AM
BuckMR2's Avatar
..in the meantime you can tape around the pipe with strong tape until you get a new one which will allow to run OK.
If there isan engine light on the dash this should go out after around 3 cold-hot start cycles.
Old 12-30-2008, 06:42 AM
Mike S's Avatar
I've not had this problem myself .... but its great that members like Buck are around as it seems to me a sort of service item that is likely to go... and its worth noting these things.
Mike
Old 12-30-2008, 06:27 PM
Jeffre's Avatar
Hi
I have contacted my dealer on the Gold Coast Australia and they want $115 for the £5 part, can you suggest an on on line parts supplier I could use as all parts sold here seem to be rather more expensive than overseas. Also I could not read the part no properly could you please clarify so I order the correct part. The split is just below the pipe in the diagram in a larger rubber hose that this pipe connects to.
Regards
Jeffre
Old 12-30-2008, 09:31 PM
Received 9,005 Likes on 4,113 Posts
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
Nice one Buck
FAQ'd
Jim
Old 12-31-2008, 09:07 AM
BuckMR2's Avatar
ORIGINAL: Jeffre
Hi
Regards
Jeffre
The pipe shown in the diagram is the inlet manifold-rocker cover breather pipe
The part number is C2S40863
It cost £4.37 + vat (now 15%) over here (UK) in Aug
Old 11-01-2010, 10:04 PM
Jeffre's Avatar
Default Limp Home Mode
Hello
My 2.1 2004 xtype has had a veiw issuesLimp Home Mode, if it has been idoling at the lights it will not go past 3000 rpm or if UIm driving at 60km for a while same thing. This dose n ot happen every time but dose happen constantly. I have replayced the aire flow meeter, put through fuel cleaner and changed the Fuel and air filters. Can any one offer some advise.
Jeffre
Finbarr1975
10-04-2015 05:32 PM
Newark Nj Gang
10-02-2015 02:39 PM
MrWhite
10-01-2015 01:43 AM
millertic
09-30-2015 08:11 PM
BlakeConverse
09-28-2015 02:22 PM
Quick Reply: 2004 2LTR Xtype Stuttering
