2004 2LTR Xtype Stuttering
Hello I am new and have owned an Xtype for the past 3 years, lately I have had some issues come up that I need help with. I have just replaced the spark plugs and will be replacing the air filter as soon as one comes in. The car is idling rough when cold and is making a popping noise and if you cover the air intake you can feel a blow back when it makes this noise. Also when you first start driving and you have too sit at lights for a couple of min, when you drive off again it will not go past 2500 revs and missies badly. In a couple of minutes it will clear and start to accelerate smoothly again.
Thanks for any help
Thanks for any help
Hi Jeffre and welcome to the forum.
Assuming ithas beenserviced at least as per the schedule and the air filter doesnt fix, have a look at this as it only takes a minute and common fault according to dealer.
Remove the 3 screws holding the engine plastic cover on, remove it and check this pipe....many split and a sturdier one is £5 from the dealer...
If that doesnt sort it maybe need to get codes read to pinpoint problem?
..in the meantime you can tape around the pipe with strong tape until you get a new one which will allow to run OK.
If there isan engine light on the dash this should go out after around 3 cold-hot start cycles.
I've not had this problem myself .... but its great that members like Buck are around as it seems to me a sort of service item that is likely to go... and its worth noting these things.
Mike
Mike
Hi
I have contacted my dealer on the Gold Coast Australia and they want $115 for the £5 part, can you suggest an on on line parts supplier I could use as all parts sold here seem to be rather more expensive than overseas. Also I could not read the part no properly could you please clarify so I order the correct part. The split is just below the pipe in the diagram in a larger rubber hose that this pipe connects to.
Regards
Jeffre
Regards
Jeffre
ORIGINAL: Jeffre
Hi
Regards
Jeffre
Hi
Regards
Jeffre
The part number is C2S40863
It cost £4.37 + vat (now 15%) over here (UK) in Aug
Hello
My 2.1 2004 xtype has had a veiw issuesLimp Home Mode, if it has been idoling at the lights it will not go past 3000 rpm or if UIm driving at 60km for a while same thing. This dose n ot happen every time but dose happen constantly. I have replayced the aire flow meeter, put through fuel cleaner and changed the Fuel and air filters. Can any one offer some advise.
Jeffre
Jeffre
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
Sep 30, 2015 08:11 PM
