Lost Key, 2000 XJ8, Dealer can't program new key, wants to replace ECM.....BIG BUCKS!
Old 06-22-2011, 01:29 PM
docbarkley's Avatar
Exclamation Lost Key, 2000 XJ8, Dealer can't program new key, wants to replace ECM.....BIG BUCKS!
Hi, I have a 2000 XJ8. Lost my keys and FOB. Dealer ordered a new key but can't program it. Wants to replace the engine control module. Any ideas??
Old 06-22-2011, 01:52 PM
Received 2,183 Likes on 1,355 Posts
Thats bs why not? Oh youre in nova scotia maybe they just dont know what theyre doing. They should have no issue, tell them to run imobilization in ids/sdd first or after key programming. If the ecu has immobilzed the car it wont start since its in theft mode.
Old 06-22-2011, 02:41 PM
Thundercat's Avatar
Thats absolutely absurd. I bet a range rover dealer could do it for you if you don't have any other Jag dealers around. You DO NOT need a new ECM. Thats BS. Good luck.
Old 06-22-2011, 08:33 PM
pdog2000's Avatar
that is BS...you totally don't need a new ECM...you should ask them to doublecheck and clarity...if they still say you need a new ECM you should report that dealer to Jaguar...
Old 06-27-2011, 08:12 AM
docbarkley's Avatar
Angry Still can't program a new key......tried ideas mentioned here!!
Very frustrated!! The only idea the dealer has come up with is to replace the ECU!! It was working perfectly, I just lost my key!! How do I get a message to Jagular?? Thxs for listening!! Doc
Old 06-27-2011, 08:20 AM
i dnont know about your area of the world, here we call jaguar of north america. ide call the dealer and just ask how to contact jaguar customer service
Old 06-27-2011, 10:56 PM
Ask them for the part number of the key they are trying to program.
If it is HNA7230AA1, it is the wrong key blank. ['98-'99 Immobilizer transponder]
If it is HJD7230AA1, that is the correct blank. [2000-2003 Rolling code transponder]
If they have the right part number, then it could have been bagged wrong and not be the right transponder. We had a whole run of those wrongly bagged keys a while back.
They may also may have to do as Brutal suggested, run the immobilization application with IDS/SDD diagnostic equipment. If it thinks it has been violated [alarm set off] that has to be done, IF you don't have a working key or remote.
Just a few thoughts.........
plums (06-28-2011)
Old 06-28-2011, 03:57 AM
plums's Avatar
Received 2,166 Likes on 1,610 Posts
@OP -- both are good suggestions that you should consider and probe carefully with your local dealer. Especially the second one, since there is no key, no fob, and yet they are presumably rambling around inside the vehicle.
MJ'S Jag
11-10-2022 08:14 AM
MarathonJohn
09-03-2015 07:59 PM
201motels
08-30-2015 08:03 PM
Will P
08-27-2015 06:52 PM
Marccutler
08-27-2015 05:11 PM
Quick Reply: Lost Key, 2000 XJ8, Dealer can't program new key, wants to replace ECM.....BIG BUCKS!
