inferior replacement coolant tank
Hard lesson being learned here after little plastic tube on original coolant tank failed. Purchased a new $40 tank off e pay which turns out to have several shortcomings. One the cap it came with says 110 Kpa while original states 140 Kpa. I put the old cap on the new tank for now. Wondering what anyone has to say about that. Also, the little bleed screw on new one leaks insanely; had to put old screw from old tank on new tank. But most upsetting is the level sensor which is stuck in the low position and does not seem to be rising to the occasion. From what I can tell, proper level closes the switch to low resistance while low coolant level is infinite or open. I wrote to seller but they are ignoring me so far. Will provide details of seller privately if anyone wants to avoid them.
I just received a coolant expansion tank from JagBits (a forum sponsor) made by Meyle. Given the number of posts of defective or poorly made tanks, I'll give this one a test with water before installation just to be sure. This one appears to be a good, well made, fully functional tank. It has the correct 140Kpa labeled cap. The top connector is fully formed. And the level sensor does not appear to be stuck at the bottom.
I recently had my coolant tank replaced on my 2005 SV8. I had it replaced because mu (probably original one) started leaking. Wouldn't you know the replacement was crummy and started leaking the day after it was installed. Thankfully my shop was great and put in a new replacement tank free of charge. It was still frustrating.
