fuel failure 44
fuel failure 44
Hi,
Fault 44 is your Oxygen Sensor, probably needs to be replaced. I have an 89, so someone else may have an additional suggestion for correcting without replacing the sensor. Not too expensive to replace, I've had to do it once about 8 years ago. Check out the info on both of these links, the first is a little more comprehensive for trouble shooting.
http://www.jag-lovers.org/ebooks/vie...Vsection=12.44
AJ6 FAULT CODES AND IDLE SETTING / AJ6 Engineering
Good Luck
Rob Evenson
89 XJ40 123K
Mobile, AL, USA
Good Luck
Rob Evenson
89 XJ40 123K
Mobile, AL, USA
