XJ40 ( XJ81 ) 1986 - 1994
fuel failure 44
Old Aug 23, 2012 | 03:38 PM
Phil63's Avatar
Default fuel failure 44
Hi, I'm a new member I bought a 1991 xj40 3.2, 3 weeks ago and it is displaying this message has rough idle, loses power, and cuts out. it also loses fuel pressure. does anyone know what could be causing this.
Thanks Phil63
Old Aug 23, 2012 | 05:39 PM
Rob Evenson's Avatar
Hi,
Fault 44 is your Oxygen Sensor, probably needs to be replaced. I have an 89, so someone else may have an additional suggestion for correcting without replacing the sensor. Not too expensive to replace, I've had to do it once about 8 years ago. Check out the info on both of these links, the first is a little more comprehensive for trouble shooting.
http://www.jag-lovers.org/ebooks/vie...Vsection=12.44
AJ6 FAULT CODES AND IDLE SETTING / AJ6 Engineering
Good Luck
Rob Evenson
89 XJ40 123K
Mobile, AL, USA
Thanks Phil63
vsol
Aug 29, 2018 09:46 PM
Pilotman11
Nov 19, 2015 12:55 AM
hoodun
Oct 2, 2015 10:13 PM
mrobinson
Sep 18, 2015 07:20 AM
Tim Goz
Sep 17, 2015 09:11 AM
