keyless entry programing
Old 01-21-2009, 08:42 AM
jagpro69's Avatar
Default keyless entry programing
I just got a 2006 XK8 and it did not come with a remote fob. I bought one off of E-bay. Does anyone know how to program it?
Old 01-21-2009, 08:45 AM
rscultho's Avatar
Default RE: keyless entry programing
Note : All transmitters being serviced must be available. If the learning process is carried out without
having all the transmitters present, all previous transmitter codes will be overwritten, rendering the missing
transmitters inoperable.
This means you must reprogram ALL transmitters, whether they were working before or not. If you don't,
Only the transmitters you program together will work.
Also, the headlight flasher is the turn signal arm. When you pull it back towards you, you flash the headlights. This is
commonly done to tell a driver in front of you that you intend to pass them.
1. Pull and hold headlight flasher back while performing step 2.
2. Turn ignition key to position 1 (DO not "start" the engine, only turn the key to position 1).
3. Now pull the headlight flasher and flash the headlights 4 times.
4. Alarm will enter programming mode. This will be confirmed by "beeps" from the alarm and flashing led on gearshift.
6. Program each transmitter (up to 5) by pressing the lock or unlock button on each transmitter once.
7. The alarm will "honk" when you press the transmitter button.
8. The alarm must honk 5 times to complete the programming. Therefore, if you are only programming one transmitter
you should operate the transmitter 5 times.
9. If you are programming two transmitters you will operate one transmitter twice, and three times on the other.
NOTE: For five transmitters you will operate each transmitter once.
The following 5 users liked this post by rscultho:
Atreus (05-30-2017), Jagged (02-07-2014), Orthodixie (03-22-2017), rbe (12-20-2017), Ronald Vennell (07-25-2018)
Old 01-21-2009, 09:03 AM
jagpro69's Avatar
rscultho, thanks a lot, it worked perfectly!
Old 01-21-2009, 11:08 AM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
I'll be sure to add this to the XK8/R FAQ thread that will soon be compiled. Good information rscultho!
Old 01-21-2009, 03:03 PM
hlgeorge's Avatar
Did not have to do all that with mine! I added a spare simply by the steps, but as pressing it once and quitting. The original remote stills work too. Mine is an 01, not an 06.
Old 10-15-2009, 02:40 PM
Received 2,183 Likes on 1,355 Posts
Chipped key and the dealer are around $60-70 cut, programming extra usually 1hr labor charge or less. Call if you have a couple dealers, and you need all keys everytime programming is done. And no you can't backdoor keys. Although jaguar has said on some models/years you can insert a programmed master key and then an unprogrammed one. But some reason the ones you do this with come back later not programmed again so i just use the ids to do it now regardless
Old 10-16-2009, 10:16 AM
Gessie's Avatar
BRUTAL, this may be a stupid question but why are there different programming methods for Jaguar models? Why does the procedure here does not work on my 2003 S type R?
Old 10-16-2009, 01:01 PM
Originally Posted by gessie
brutal, this may be a stupid question but why are there different programming methods for jaguar models? Why does the procedure here does not work on my 2003 s type r?
???thats a question to ask the ford/jaguar engineers why they decided to do that
Old 10-16-2009, 06:37 PM
macbut999's Avatar
Heres the procedure
1. Insert key into ignition
2. Turn the key to ''I"
3. Turn the key to "II" and back to ''I'' quickly 4 times
4. Alarm system should chime once when the key is back to ''I'' for the
4th time
5. Remove the key from the ignition
6. Press any button on each key fob and the alarm system will chime
for each fob if it has been programmed correctly
NOTE: Some models will require you to press all of the buttons simultaneously on key fob and the alarm system will chime.You will need to repeat this step for each key fob.
7. Press unlock/lock/boot release etc to make sure everything works
Pay particular attention to point 6, every fob you have must be programmed at the same time although you only need use one key in the ignition.
The following 2 users liked this post by macbut999:
jjd247247 (02-15-2015), Orthodixie (03-22-2017)
Old 10-16-2009, 06:58 PM
Gessie's Avatar
BRUTAL Just venting, now I have another problem with my baby, ENGINE SYSTEMS FAIL, DSC INOPP, PARK BRAKE FAULT, the ABS LIGHT is on, and the SERVICE ENGINE LIGHT is on.
I created a thread on the S type Forum in case you would like to help me.
Old 10-16-2009, 09:29 PM
that all is related but you need codes to see what route to take in diag
Old 11-08-2009, 11:20 AM
captjsh's Avatar
Default Transponder key Programming
Is this the proceedure for the remote or the key? I have a 2004 xk8 and only one key. I see transponder blanks in the internet but how/where do you get the key cut and linked to the car?
Jim
Old 11-08-2009, 04:03 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
The programming is for the FOB only. A key will have to be cut/programmed by the dealer or a very well equipped locksmith
Old 01-19-2010, 10:00 PM
edsterp's Avatar
whats the programming the keyess entree procedure for a 1998 xk8?
Old 01-20-2010, 04:38 AM
test point's Avatar
See the FAQ sticky above under Remote Keyless Transmitter (key fob) Programming.
Old 01-24-2010, 03:11 AM
edsterp's Avatar
Default cant find
hey bud I couldnt find that thread. could u reply with a link?
Old 01-24-2010, 07:00 AM
test point's Avatar
Look alphabetically for 'REMOTE KEYLESS TRANSMITTER (key fob) PROGRAMMING' here:
https://www.jaguarforums.com/forum/s...ad.php?t=29800
Old 02-03-2010, 06:06 AM
H20boy's Avatar
I did a quick search just in the s-type section and found this thread...see if it helps.
Quick Reply: keyless entry programing
