Mid rise lift
Old 07-31-2014, 06:10 AM
RJ237's Avatar
Received 2,783 Likes on 2,227 Posts
Default Mid rise lift
I often see comments on the forums by members who wish they had a lift.
A few years back I bought a Atlas MR-06 portable lift. It weighs 1000 lbs is rated for 6000lbs and rises over 4 ft. I can get my XK8 windshield frame to the ceiling. Power requirement is 30A 110V. When I bought it I picked it up with a Ford Winstar, as it comes on a 4'X8' pallet. It can be moved around fairly easily.
Atlas® MR-06 Portable Midrise Lift
The following 4 users liked this post by RJ237:
GGG (08-01-2014), Loxmth (07-31-2014), reb1999 (08-06-2014), The Coupe (07-31-2014)
Old 07-31-2014, 07:40 AM
cjd777's Avatar
Received 1,323 Likes on 735 Posts
Default Lifts
I also have been looking at lifts. The big issue is the height, most poles go in the 142 inch range and this is way too high for the average garage. I have a two block build up, after fill, and if I place this lift between the rafters it is only 1 inch above the bottom. I have found out the concrete is fine as far as the PSI (4000lbs), but I had a crack appear on the other end of the 40 foot that has a good 1/2 inch separation. Of course the builder says this is normal and is going to fill it with a patch. Concrete is only 1 year old, so I'm waiting a little longer to see what else happens.
The lift I'm looking at is only 111 inches high and is 9000 lb. Surely it will save my back, even if I set on a roller stool to work under the car.
Auto Lift AL2-9K-FP 9,000 lb. Capacity Symmetric Two Post Car Lift
Wayne
Old 08-01-2014, 04:00 AM
johns55's Avatar
I have a MaxJax lift and it works very well. It goes up about 48" and can get a little higher with pad extensions. Height of the garage ceiling being the limiting factor.
Old 08-01-2014, 04:29 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
Originally Posted by RJ237
........ A few years back I bought a Atlas MR-06 portable lift ........
That's a terrific piece of kit although sadly not one I could justify purchasing.
Does it slide under the XK8 or do you have to first raise the vehicle slightly to get sufficient clearance?
Old 08-01-2014, 05:52 AM
RJ237's Avatar
I built a pair of ramps to raise the car, just 2X4 laid flat with plywood on top. That was when I had a Z3, but the XK8 needed shock mounts and was also low. Now I still use the ramps because it helps me line the car up.
It was necessary for me to buy the lift, I am no longer able to work on my back without feeling dizzy and nauseous. I use a small furniture dolly with a milk crate for a seat. It comes with low and high pads. To use the high pads I have to first raise the car, then put blocks under the wheels to slide the high lifts in place. I also use hardwood blocks to be sure the exhaust doesn't rest on the arms.
GGG (08-01-2014)
Old 08-03-2014, 03:18 PM
Sentinelist's Avatar
I'm considering getting the scissor lift at Harbor Freight within the next year. It's well rated, and can be had for just a bit over $1k USD with one of their 25% off coupons.
Automotive Scissor Lift
It still won't solve my fear of a car collapsing on me, which is why it's gotta be 99.999% dependable. This one seems to be, but I'm still open to other options under $2k next year.
Old 08-03-2014, 03:31 PM
Jandreu's Avatar
Those scissor lifts scare the hell out of me.
Old 08-03-2014, 03:54 PM
RJ237's Avatar
It looks like a knockoff of my AJAX lift. They both have a mechanical lock that has to be released to lower, that's why the bike clutch handle on the pump module. The center shaft is notched to receive a shoe which catches to keep it from collapsing.
But it requires 220V where the AJAX runs on 110V
studentper
02-20-2016 09:43 PM
SD96XJ6L
11-05-2015 10:47 AM
vwbusbits
10-13-2015 03:43 AM
tomkilner
10-09-2015 07:10 AM
hoodun
10-06-2015 08:34 PM
Quick Reply: Mid rise lift
