Using Waterless Coolant in XK8
Old 03-27-2013, 06:05 PM
Lanny's Avatar
If you interpreted my post as a slam against Evans coolant, then you read it wrong. I was simply reporting what happened to one persons car. I was not in the drivers seat, he may have ignored the temperature gauge. My point would be that just preventing a boil over is not necessarily the desired end result.
  #42
Old 03-27-2013, 06:07 PM
Ok I understand what your saying Mike.
But that doesn't rule out that water reaches that 15 psi faster at lower temperature because of its lower boiling point.
It's my experience that when an engine has been boiling in most cases there is damage to the engine (cylinder head gasket) which could have been avoided with a coolant with a boiling point that's higher ?
Point being, compared to waterless coolant the margin from normal operating temperature until boiling point and high pressure is a lot smaller with normal coolants.
P.S. Lanny I don't see your post as a slam against evans I wouldn't mind if it was either
  #43
Old 03-27-2013, 06:36 PM
Received 2,255 Likes on 1,840 Posts
Without knowing the expansion coefficient of the waterless coolant, the above may or may not be true. I see nothing on their website that discusses this.
  #44
Old 03-29-2013, 04:44 AM
I send them an email asking for the expansion coefficient, waiting for a reply.
  #45
Old 11-01-2013, 07:54 PM
geroge3's Avatar
Default waterless coolant
I had a shop in Seattle called Community automotive service replace my coolant with the waterless coolant. They seemed to be the only one that knew about it. on my Jag XJ-S Also on my Dodge Viper, Waterless coolant helped in running engines a little cooler. I do recommend waterless coolant for the life of the engine. Good luck mate.
  #46
Old 11-02-2013, 11:25 AM
Default In My Car
I had my coolant flushed and replaced it with Evans, I just wanted a lifetime solution and to reduce my concerns about corrosion (parts are starting to get harder to find for the car). Put in both high performance intercooler and main water pumps. No issues so far.
  #47
Old 11-12-2014, 09:38 AM
avos's Avatar
Received 1,063 Likes on 759 Posts
I have just changed to Evans myself for the engine cooling system (not the intercooler circuit), and will be able to give some more details in a couple of weeks.
For now I have set it up as pressure less.
  #48
Old 11-12-2014, 02:10 PM
XxSlowpokexX's Avatar
Avos. You separated the IC circuit? Did you do a write up on that?
The only reason I'm not running Evans in my jag is because I don't feel its good for IC use. I use it otherwise in all my high performance cars with great success.
  #49
Old 11-12-2014, 10:55 PM
avos's Avatar
I'll do write up later when I also have some test results, separating is easy though.
Better not use evans in the intercooler circuit, it will lower the heat transfer capabilities, which will rob power quicker
  #50
Old 11-15-2014, 03:50 PM
Hare's Avatar
Ok time to add my 0.02 pennies.
I have changed over my Hayabusa and two KTMs to Evans waterless coolant. No problems to report at all.
Also swapped over my 66 MGB. Car is happy and so am I. I personally like the idea of less pressures on my components.
Jag is next on the list.
mrplow58
01-21-2024 05:53 AM
duecedriver
12-25-2015 11:47 AM
willtoliv
10-02-2015 12:18 PM
Johnken
09-15-2015 05:46 PM
jimmiejag
09-09-2015 02:56 PM
Quick Reply: Using Waterless Coolant in XK8
