window lowering with door handle but does not return when closed...can we correct it
Old 06-29-2008, 10:40 PM
GordoCatCar's Avatar
Default RE: window lowering with door handle but does not return when closed...can we correct it
The windows need to bere-indexed. Try programming it yourself. Raise windows all the way holding switch down for at least 5 seconds after it has reached the top. Same for bottom, lower all the way and hold the switchdown for an additional 5-10 sec.gordo
The following 2 users liked this post by GordoCatCar:
Berdes (02-01-2015), Lufferman (01-29-2015)
Old 06-30-2008, 01:50 PM
Even then, that won't always fix the problem.
A lot of times my coupe will do that, I'll re-index them, and the next time I open the door, the window won't go back up.
Other times, the window won't go down, and the entire door will go dead, but then start working in about 20 minutes.
Old 06-30-2008, 01:59 PM
hlgeorge's Avatar
If power is lost for 20 minutes then you are holding the switch too long in the up or down position.
Old 06-30-2008, 07:23 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
You should also here a 'click' when the window has programmed successfully in each the up, and down location. Somewhere between 3-5 seconds is a good time frame to listen.
The following 2 users liked this post by H20boy:
Lufferman (01-29-2015), papastoy (06-16-2016)
Old 07-01-2008, 12:18 PM
ORIGINAL: hlgeorge
Yeah, but it will lose power while I'm not in my car.
I'll go out to get in it, and open the door, and nothing will work in the door.
Old 04-06-2012, 02:58 AM
cbxsage's Avatar
My windows will drop everytime I actuate the door handles, inside or out, I can roll them all the way down by using the door handles. Will reprogramming correct this?
Bill
Old 04-06-2012, 03:07 AM
GGG is offline
Received 16,799 Likes on 12,168 Posts
Bill
As you open the door, the windows are meant to drop a few millimetres to clear the top sealing rubber. When you close the door, the window should raise again to lock into the seal.
The problem after loss of power or low battery is the window drops but doesn't go back up again automatically when the door is closed and has to be lifted with the switch. This is what reprogramming corrects.
Old 04-07-2012, 01:01 AM
cbxsage's Avatar
As you know, my battery has been disconnected several times. This is not a factor with the '95 and my XK didn't come with any Jag Owner's guides.
Thanks a lot Graham, as usual, your guidance and comments are reassuring at the very least...
Now, if I can only find a key fob to play with...
Thanks,
Bill
Old 04-19-2012, 05:28 AM
meliores's Avatar
I have the exact same problem in my XKR after having a flat battery. I just followed the instructions here and it seems to have fixed it. Thanks! : )
Old 04-19-2012, 08:31 AM
Paul Pavlik's Avatar
Originally Posted by toddster
new to this forum but if seems to have great help...and boy do I need it, I have a problematic xk8...oh but who doesn't.....lol
I have a question about my 97 xk8 convertible, when I open the door the window lowers a tad but when I shut the door it does not return closed? is this a programming issue? can I fix it myself?
thanks for the help
For those that have a Owner's Manual, This is covered in detail.
Of course, on some used XKs the Owner's Manual is missing.
Old 01-29-2015, 01:59 PM
Lufferman's Avatar
No owners manual here! Don't need one! You guys are the best! Going through this car one system at a time has been a labor of love. Thanks for all time and know how.
Old 01-29-2015, 02:15 PM
GGG is offline
If you change your mind ( ) you can download the VEHICLE DOCUMENT SET for your model from here:
https://www.jaguarforums.com/forum/x...006-faq-67827/
All the Handbooks that would have been with 1996-2006 XK8/XKR's available for download as PDF's.
Old 01-29-2015, 02:37 PM
Lufferman's Avatar
IT WORKED PUURRRFECT!!! 😈
3 to 5 seconds listen for the click.
No owners manual here! Don't need one! You guys are the best! Going through this car one system at a time has been a labor of love. Thanks for all your time and know how.
Old 01-29-2015, 03:01 PM
H20boy's Avatar
You can download the manual in sections from topix...and put them all together into one PDF to print it for your glovebox if you like Check out the FAQ in this subforum for the link to take you to it.
Old 01-29-2015, 05:52 PM
mjlaris's Avatar
If the procedure above does not fix the problem, then you likely have a stuck/bad micro switch. Reverend Sam has a video on how to fix this problem. The micro switches are about $25 each.
Old 01-29-2015, 10:49 PM
Johnken's Avatar
Received 1,808 Likes on 1,115 Posts
Your kind offering of the Owners manuals reminded me of something. I was looking at Jaguar XK8's on YouTube and found a 40 minute copy of the VHS tape Jaguar included with all new 1996 (could have been 1997 not sure) new XK8 purchases. It was fun to watch, pretty much covered all the feature / functions described in the owners manual. It as also interesting to see the changes from what they describe to what I have on my 1998 for instance. Thought you might find it intersting.
Old 02-01-2015, 11:40 AM
Berdes's Avatar
Default DriversWindow
Came to the rescue again, the drivers window would not return to the up position, followed the instructions from you guy's, and VIOLA! Fixed.
Thanks once again.
Old 05-12-2015, 09:47 PM
wabisabi's Avatar
Okay, I have a variation on this problem. When I open the passenger door, the window
goes down and then immediately goes back up! It doesn't wait for the door to be closed.
So I'm concerned it's not sealing as well as it should. Can I correct this? I've tried
re=programming the window several times. Thanks for any input!
Quick Reply: window lowering with door handle but does not return when closed...can we correct it
