Letting Convertible Top Down In 30-40 Degree Weather Is This Safe ? Please Advise
Old 01-27-2010, 03:34 PM
jagxkrtoofast's Avatar
Banned
Arrow Letting Convertible Top Down In 30-40 Degree Weather Is This Safe ? Please Advise
I want to know if its safe to let the top down in 30-40 degree weather ? Someone told me that the manual doesnt advise in the temperatures the top can be lowered. Its cold here where I am at but the tempertures has being going up to 40-45 degrees and sometimes I like to drop the top but I didnt because I wasnt for sure if I can do it in these tempertures. I miss 50-60 degree weather I cant wait til summer.
Old 01-27-2010, 03:56 PM
RCSign's Avatar
Jagxkrtoofast
It's not safe you might get frostbite.
Doug
Old 01-27-2010, 04:56 PM
Coastrider's Avatar
We were out in about 36 degree (f) weather last month. Sunny skies, top down, heaters on as well as the heated seats and it was spectacular.
We were out yesterday in 50 degree (f) , (about 10 degree C here) and another great drive with the top down under sunny skies.
Cheers,
Mark
Old 01-27-2010, 09:01 PM
Gus's Avatar
Gus
Gus is offline
Received 2,207 Likes on 1,700 Posts
The way I see it is that Pentosin CHF11s will pour at -55c or -67f. I think it should not be a problem. http://www.gusglikas.com/AutoRepairHydFluid.htm
Old 01-27-2010, 10:30 PM
test point's Avatar
Received 1,110 Likes on 932 Posts
The only issue I can see is the 'rubber' membrane between the canvas top and the interior trim. I have never seen any cautions or reports of failures. Go for it.
Old 01-27-2010, 10:57 PM
Default Just to clarify
The manual DOES say do not lower top below 40 degrees.
Old 01-28-2010, 05:48 PM
GordoCatCar's Avatar
I think the issue is that on a new car, the fabric is can be tighter when its cold. However, the fabric on our cars has been loosened up considerably and I dont think it should be a problem now.
Old 01-28-2010, 07:40 PM
Gus's Avatar
Gus
Gus is offline
If you want to open it then go for it! If it were a problem it would have a warning signs.
Old 02-15-2010, 06:58 PM
Banned
Am I missing something here ? I checked the Jaguar manual and it states do not operate convertible top below 5 Degrees because it may damage the fabric. Where are you getting below 40 degrees ?
Old 02-15-2010, 07:39 PM
Gus's Avatar
Gus
Gus is offline
It is 33 deg. At my home right now and I would not have a problem operating the roof. Last xmas I opened the roof for my wife and I to see the festival of lights in our area. Did anyone tell me I could do this? No! I did it because I wanted to. Keep in mind that this car is not a fine piece of cut glass crystal it is a car.
Good Luck!
Old 02-16-2010, 03:09 PM
Banned
So its alright to let the top down in 30-40 degree weather. I just want to confirm this. Thanks
Old 02-16-2010, 03:16 PM
SeismicGuy's Avatar
I just can't help myself but is this guy for real?!?!?!
Doug
Old 02-16-2010, 03:32 PM
daddyo007's Avatar
Man this is going to get fun .
I think Sally said it best........................yes, yes, yes,.......................
http://www.youtube.com/watch?v=5nNhO...eature=related
Sorry could not help my self but if this doesn't answer your question nothing will.
Old 02-16-2010, 03:57 PM
Gus's Avatar
Gus
Gus is offline
Oh God Yes! !! !!!
Old 02-16-2010, 04:12 PM
newbie1's Avatar
Default Putting top down in cold weather
The issue might well be the rear glass in the top. I had one implode on a Chrysler some years ago when it was about 35 outside. It was not pleasant!
Old 02-16-2010, 04:28 PM
SeismicGuy's Avatar
What I meant was not necessarily limited to this specific post but generally many of the other posts as well. Sometimes it seems like a conversation with one of those "intelligent" machines where you can have a discourse with "someone" you think is a real person but the responses are merely generated by some computer at the other end. There are times where I think the op is just some spammer but other times the discourse seems almost legit.
Doug
Old 02-16-2010, 04:50 PM
H20boy's Avatar
Received 1,144 Likes on 750 Posts
^ Doug, I sense the same thing, but more like the OP isn't satisfied with any reply that is given.
Old 02-16-2010, 05:12 PM
Gus's Avatar
Gus
Gus is offline
What!
Old 02-16-2010, 06:01 PM
H20boy's Avatar
try to keep up gus j/k... see other OP original threads for trend
Old 02-20-2010, 02:14 PM
LuxXKR's Avatar
I do this regularly, Put the heating on manual and maximum temp & blow then set it at your feet, you will be warm up to just about the top of your ears, I would advise putting the cover over the folded hood. If it aint rining get the top off, otherwise why do you have it?
Quick Reply: Letting Convertible Top Down In 30-40 Degree Weather Is This Safe ? Please Advise
