Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
2002 X-Type Amp/Sub Install
Old Feb 14, 2009 | 06:10 PM
starvinmarvin08's Avatar
Default 2002 X-Type Amp/Sub Install
Factory head unit (No NAV) with 4 speakers, 1 in each door. I've done an amp and sub install before, but on an aftermarket head unit.
How do I make the sound connections and power connections? I don't want the amp powered all the time, do I have to wire in a switch? Or is there a factory amp that the head unit turns on I can wire into.
(edit)
Need to know whats what on the factory wiring harness so I know what to tap into.
Old Feb 15, 2009 | 01:15 PM
christo's Avatar
There are lots of different ways to do this. But I pulled the headunit and attached a low level to rca converter and then ran my rca's to the trunk. I figured I would eventually replace the radio so all the wires would have been ran for me. I also ran a remote turn on wire from there as well. There are many people here who state there is something you can tap into in the trunk - I couldn't find it for the life of me. Ofcourse you will need to run a line from the battery to the trunk and the mounting screws for the factory sub make a great ground. I have totally removed the entire stock sub...
Here are the wire colors I got from a bestbuy tech, he warned me that they are just a guide so I will pass that on to you. I have a 2003 X-type.
12v - brown/white
ground - black
ignition - yellow/green
dimmer - orange
for factory amp turn on - n/a - go figure - maybe there isnt one?
speakers
left front - white + yellow -
right front - white/red + yellow/red -
left rear - white/blue + yellow/blue -
right rear - white/green + yellow/red -
Any questions let me know...
Steviedee1st
Nov 28, 2023 06:32 PM
way2far
Aug 31, 2022 09:26 AM
the whittys
Sep 15, 2015 01:47 AM
DatDude
Sep 8, 2015 11:36 PM
avern1
Sep 6, 2015 04:22 PM
