Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
2002 X-type sterio question
Old May 18, 2008 | 09:01 PM
Grim001's Avatar
Default RE: 2002 X-type sterio question
So you are wanting to loose the Nav unit and put in an aftermarket radio? It can be done but you will have to buy the heat/AC controls for the normal jags and then get a facia plate for aftermarket radio. Eaby sells the ac/heater control just look under jag, either radio or ac controls. I ordered my fascia plate off of www.installer.com part # 99-9500. I got the wiring kit from ebay using a search for part number PC2-81-4, you can do it in google too. You may also need the antenna adapter part number PC5-100 or look up Hirschmann antenna adapter to motorola. There is also a steering wheel adapter if you want to use the steering wheel controls, search for part number PC99-X47. Hope this helps. I am in the process of putting in an aftermarket nav unit and it took me weeks to find everything. This site, www.nexxia.co.uk, has everything but it cost about $200 to get it from them. I spent less than half that by piecing it together.
Old Jun 7, 2008 | 10:19 AM
fireantz's Avatar
Do you know if you would be able to modify that single din fascia from installer.com to be a double din?
Old Jun 7, 2008 | 02:14 PM
Grim001's Avatar
Yes you can. I am doing it now. My unit is double din as well. Just need a good knife to cut through the plastic part going across and then trim it to look nice.
Old Jul 18, 2008 | 03:28 PM
sbxt's Avatar
You may want to throw that stock unit on ebay... They pull a VERY good price. You'll probably pay yourself back a good portion for the money you spent on the aftermarket stuff.
Steviedee1st
Nov 28, 2023 06:32 PM
way2far
Aug 31, 2022 09:26 AM
the whittys
Sep 15, 2015 01:47 AM
DatDude
Sep 8, 2015 11:36 PM
avern1
Sep 6, 2015 04:22 PM
