Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Inside a jag radio
Old Jul 16, 2009 | 11:07 PM
veffremov's Avatar
Default Inside a jag radio
I got a CD/Radio unit from a late model S-Type and decided to peek inside. A few photos of the effort:
http://cid-929c26e96a635de1.skydrive...%20Jag%20Radio
The main CPU is Fujitsu MB90F574/A flash based 16 bit microcontroller. The audio DSP is SAA77064. The tuner frontend is SAA6588TV. The optical unit is made by Apline.
The D2B interface IC is a mystery has label 2440 OS8101. I could not find any documentation about it, except it is also used in some Benz units. Supposedly ST micro still manufactures the clip, but has no info whatsoever.
I'll try to peek in the CPU software to see if I can learn more about the D2B bus.
Old Jul 18, 2009 | 10:49 PM
FloridaJag's Avatar
Nice job. Gives the appreciation for what goes into these radios.
Old Jul 23, 2009 | 02:50 PM
super_jag's Avatar
I opened mine up as well, but it was to change the leds.
Old Sep 10, 2009 | 05:52 AM
ecol2's Avatar
does the early s type have changeable LEDs
Old Sep 13, 2009 | 05:52 PM
veffremov's Avatar
Depends, what you mean by changeable. Defenitely there are no sockets, you need a soldering iron to remove the old ones and sloder new ones in place.
philwarner
Oct 4, 2024 01:37 PM
Dz1rfj
Jul 17, 2018 10:29 AM
cissdm
May 3, 2016 06:02 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Numwen
Sep 6, 2015 12:30 AM
