Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Will a standard 4 screw speaker fit into an 02 x-type?
Old Oct 15, 2010 | 02:20 PM
jeffrimerman's Avatar
Default Will a standard 4 screw speaker fit into an 02 x-type?
I saw pics on a post that seemed to show the speakers for an x-type to have 3 screws holding it in, but the aftermarket speakers have 4 screws. Will they work or do I need an adapter? I saw some polk audio that seem to be really efficient for non amp and have a range down to 35hz. I think they means it will have lower lows than the ones with 50hz, but correct me if I'm wrong. Thanks=)
________
Lovely Wendie99
Old Nov 1, 2010 | 11:12 AM
androulakis's Avatar
I had a Boston Acoustics 6.5" component sent mounted into the doors of my X-type. I removed the factory speaker in its entirety (including the plastic housing). And drilled 4 holes for the screws in the metal. I used those metal clips that act as a retaining nut that come with the speakers to hold them down, and the grill frame to act as a seal.
Here's a pic.
Attached Thumbnails Will a standard 4 screw speaker fit into an 02 x-type?-dscn0583.jpg   Will a standard 4 screw speaker fit into an 02 x-type?-dscn0581.jpg
Old Nov 2, 2010 | 08:45 PM
gragner66's Avatar
sounds like it looks good might be the way i have to go
aholbro1
Dec 29, 2024 06:46 PM
kevinl
Oct 31, 2019 06:15 PM
mbergen
Oct 23, 2019 10:26 PM
metalmarty
Sep 11, 2015 07:05 AM
simo5555
Sep 9, 2015 06:22 AM
