E type ( XK-E ) 1961 - 1975
70 Roadster Cylinder Head Stud Removal Questions
Old Oct 31, 2022 | 11:40 AM
johnrmclean's Avatar
Default 70 Roadster Cylinder Head Stud Removal Questions
I'm trying to strip down my 70 motor myself and looking for some tips. I already have the head removed and am on to the cylinder head studs. Im trying to reduce the height of the motor before I pull it out from under the car.
!. What is the thread size on the studs?
2.Is the bottom thread right through the water jacket and the lower block?
3. My engine is seized and the studs appear quite corroded. In the event I snap or strip a stud on the bottom end is there a procedure to correct it?
4. Any removal tips are appreciated!!!
Old Oct 31, 2022 | 06:43 PM
Fraser Mitchell's Avatar
With the long stud engines you must be VERY careful when removing the studs as they can corrode badly above where they screw into the bottom of the block. It is not unknown for the corrosion to be so bad that the stud snaps off leaving a small stub at the bottom. However, there is a core plug by each stud and normally, these would be removed for inspection and clearing of crud. At the same time each stud can be examined for corrosion. If bad then use of anti-seize oil can help in extracting a stud. When I removed mine, corrosion was present, but not bad enough to cause a breakage. When I got mine all out on the engine of my 1980 XJ6, I vacuumed out the stud holes, then got a friend with access to a shop, to make up a thread clearance tool using a plug-tap. I replaced all the studs with no problems then.
Old Oct 31, 2022 | 09:31 PM
Default Stud Removal
Thanks for the advice. What method / tool did you use to remove your studs? I will be putting new studs in.
Old Nov 2, 2022 | 09:40 AM
Kittylover's Avatar
grasp the stud near the block deck , TRY to titen the stud a WEE BIT, this should break the rusty grasp of being where they have been for over 50 years!!!Remove the core plugs, as an access to soak the base thread with penetrating fluid- allow to sit overnite.If one breaks, it is a machine shop job to remove, but you are going to re-bore anyway.
JacobyJaguars
E type ( XK-E )
Nov 21, 2021 11:24 PM
sidescrollin
May 24, 2018 01:04 PM
JRR705
General Tech Help
Mar 12, 2016 03:54 PM
JRR705
E type ( XK-E )
Oct 27, 2015 03:31 PM
M90power
Aug 30, 2012 08:45 PM
