E type ( XK-E ) 1961 - 1975
Can you use a cigarette lighter trickle charger on an e type Jaguar.
Old Feb 1, 2024 | 01:32 PM
Greg1967OTS's Avatar
Default Can you use a cigarette lighter trickle charger on an e type Jaguar.
I’ve checked the lighter and it has electricity when the ignition is off. So technically it should work but I’d like to hear from someone who has actually done this.
I have a 1967 OTS.
Old Feb 1, 2024 | 09:32 PM
Valerie Stabenow's Avatar
Others with more electrical creds than I need to weigh in, but I would not feel comfortable doing that in my 69. That is spindly wire, maybe 12G? There are folks on the MG forums who have done something like this, also installed a charging "post". Any thought about using a modern CTEK battery charger/maintainer?
Old Feb 2, 2024 | 03:36 AM
dibbyandco's Avatar
I agree with Valerie. It's easy to use a maintainer (I use an optimate on my E, and a Ctek on my F) which does a better job . I just clip it to the battery with the bonnet not fully shut.
Old Feb 2, 2024 | 02:47 PM
Default Trickle charger
Thanks for the advice. I just ordered a Ctek from Amazon.
Old Feb 3, 2024 | 04:38 PM
enderle's Avatar
I think that is wise, I wouldn't trust that old wiring either. (and I, also, use a maintainer). Best of luck!
Old Feb 10, 2024 | 11:26 PM
ericisback's Avatar
I suspect you were hoping to be able to use a battery maintainer hooked up to the cigarette lighter, so you wouldnt have to open and close the bonnet to mess with the charger.
I installed the battery connection part of my Ctek charger to my battery with eyelet terminal connectors (not clips), and then ran the end of the the wire with the “quick connect” connection to my wheel well. Now, I can quickly connect/disconnect the Ctek to the battery without having to mess with the bonnet:
It has worked great for years. Hope this idea helps.
Old Feb 13, 2024 | 09:49 AM
great idea. Thanks for the tip.
Old Feb 14, 2024 | 10:13 PM
Excellent idea. I’ll give it a try.
Old Feb 15, 2024 | 08:20 AM
Default The CTek
I would be careful, though, about driving around with that connector hanging out.
Old Feb 15, 2024 | 10:12 AM
ericisback's Avatar
I’ve done it for years. No issues 👍
Old Feb 16, 2024 | 06:58 PM
lrgridley's Avatar
I'd certainly want to put a fuse (maybe 5 amp) close to the battery at the (+) terminal. Better safe than sorry!
Old Feb 17, 2024 | 03:39 AM
dibbyandco's Avatar
Over here in the UK, my concern would be the amount of wet and crud that could be thrown up onto the connector. Probably wouldn't live long being exposed there. If you drive in nice dry conditions, probably not a problem. Lucky you!
Old Feb 17, 2024 | 06:43 AM
ericisback's Avatar
The car never sees rain.
jgwjr
Jul 25, 2022 06:04 AM
leoholland
Jul 2, 2022 06:52 AM
barriectaylor
Mar 11, 2022 08:23 AM
BigSpanish
Nov 14, 2018 10:27 AM
Jul 1, 2012 09:25 PM
