E type ( XK-E ) 1961 - 1975
Drop down console for Series 1,4.2 liter
Old Jan 27, 2020 | 02:30 PM
jphass's Avatar
Default Drop down console for Series 1,4.2 liter
Hi,
I hope this is a simple question. In order to drop down the center console with the gauges and switches in order to get to the fuses, there is a screw at the upper left and one at the upper right corner that must be unscrewed. Is that all, or in addition to that, does one need to remover the plastic bar that is part of the center console that identifies what each switch is, e.g., wiper, washer, map light, etc.
My car is an August 1966 build, US model year, 1967.
Thank you.
John
Old Jan 27, 2020 | 03:44 PM
Bob_S's Avatar
Hi John,
All you need to do is unscrew the 2 screws at the upper left and right if everything is perfect. But being that these car are now 50/60 years old things change, things bend, poorly reassembled etc. You may have to remove the radio console to open the flip down panel. The transmission cover/center console maybe pushing up on the radio console preventing the flip down panel from opening. It will probably take some messing around with the transmission cover, center console, pushing down the radio console while installing it, leaving out the rubber strip for the plastic ID strip and adjusting the flip down panel hinge.
Hope this helps.
Old Jan 27, 2020 | 03:50 PM
jphass's Avatar
Thanks, Bob. I appreciate your response.
John
Old Jan 27, 2020 | 06:55 PM
alfred's Avatar
yup, just those two screws removed to drop the center console.
Old Jan 28, 2020 | 10:32 AM
jphass's Avatar
Thank you for your reply and confirmation.
John
Old Jan 29, 2020 | 04:16 PM
bazjag's Avatar
After removing the two thumbscrews, CAREFULLY lower the panel while watching the clearance at the lower edge. The strip can be broken if it is forced. Some cars will have sufficient clearance, some require the plastic strip to be removed. If the console is sitting higher than original then more will need to be done.
cdnp62000
E type ( XK-E )
Jan 17, 2016 12:51 PM
elwoodboll
May 31, 2013 05:07 PM
Mcdna311
May 30, 2013 04:03 PM
joeinthedark
Aug 14, 2011 11:36 PM
Raheny
Jun 23, 2009 10:13 PM
