E type ( XK-E ) 1961 - 1975
Electrical anomaly
Old Oct 20, 2013 | 09:33 PM
vagt6's Avatar
Default Electrical anomaly
Hello all Ijust purchased a very nice 70 series 2 4.2. Runs great but I have an electrical gremlin as follows. Thanks in advance for all suggestions it's great to be in this universe of Jags.
It blows a 50 amp horn/tach etc. fuse when I engage the side lamp/head lamp switch. So I've run out of 50 amp fuses (which I've found on eBay for about $5 apiece) and wondering where I might begin to solve this electrical gremlin.
All and any input is appreciated.
Thanks friends.
Old Nov 8, 2013 | 04:59 PM
lbink's Avatar
Hi Vagt6,
Seems like an odd issue. But knowing that these cars weren't always carefully maintained, I'm not surprised.
I assume the headlamps (dip) don't switch on when you turn the switch.
Two things must be the case.
A mis wiring in behind the central dashboard. Compare the color codes with a proper workshop manual.
You mst have a short in the wiring. Pull the multiplug on the bonnet. If you don't blow a fuse, you can rule upt the harness inside the bonnet.
Good luck!
Old Nov 9, 2013 | 05:44 AM
vagt6's Avatar
Originally Posted by lbink
Hi Vagt6,
Good luck!
lbink thanks for the input! Well, I fixed the initial problem, above, it was a loose contact on the fuse block. However, now my headlamps are twitchy and low beams don't work at times. BTW wiring in this car is like new, as it is a concours car. I'm beginning to think it may be the headlamp switch.
How may I test the headlamp switch? At least this isn't a fatal problem, I seldom use the lights anyway.
I appreciate your help, thanks very much.
--Mark in Charlottesville
bdboyle
Nov 6, 2015 02:07 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
magmedia
Sep 28, 2015 09:49 PM
