E type ( XK-E ) 1961 - 1975
Etype parts
Old Jan 28, 2025 | 11:35 PM
SpecQra's Avatar
Talking Etype parts
I have found a suitcase FILLED with parts from our last Etype
99% of the items are new and in sealed bags. Need to sell these as quickly as possible to someone who can use it, either individual pieces or the entire lot! Total Value is $4K. Make me an offer :slight_smile:
Pictures available for all items - see attached file
BD40512 Kangol Seat Belt, Dark Grey with Stalks
C33151 Interior Rearview Mirror head
C34711 Sidelamp LHF with bulb
BD332/5 Retainer
BD35694 Headlamp Peak RH
BD12345 Wire Wheel Chrome Spinners, 2 Right + 2 Left + Spinner Removal Tool
C28583 Dash Legend Switch Strip (No Heated Rear Screen)
BD20590 De-mister Bezel Center
BD20592 Demist Bezel outer
CBC1448 Mounting Grommet
8641 Indicator Warning light Lens
8837 Handbrake Pawl Tension Spring
C386 Pulley washer
C23627 Brake Reservoir Cap, Rubber
8836 Handbrake pawl
EBC10199 Gaskets
C937 Fuel Tank Sender Unit Gasket
SSTC-32-37 or B009AG10EK Stainless Steel T-Bolt Hose Clamp 1.25" - 1.46" (32mm-37mm)
C13932 50 Amp Fuse
CAC9295 Bush upper wishbone
BD24400 Folding Luggage Hinge Boot Board
BD37600 Chrome ‘V12’ Boot Lid Badge / Script for E-Type Series 3
SH505051J Set Screw
EBC2552 Oil Ring
8980 Handbrake adjusting nut
8845 Handbrake Adjusting bolt
C32849 Switch 107SA On Off
338023J Pair of Floor Plugs
JLM1264 Final Drive Seal/ Drive Axle Shaft Seal
BD32160 GRILL BADGE EMBLEM CAT FACE
C34258 Breather Bung
C4111629 CLAMP FOR BREATHER BOOT
CBC6923 PINION OIL SEAL FOR THE DIFFERENTIAL
BD12326 Glovebox handle
EBC2997 valve keepers
C44386 Breather Cap
BD24296 Cubby box lock and key
8940 E-TYPE HANDBRAKE RETURN SPRING
C34360 Circlip
C37668 Spiral binding
C23860 Radiator Cap, NEW
C23860 Radiator Cap, USED
BD19561 Screen pillar RH
C35077 Pipe Clip, Balance Pipes
LK11032 Lockheed Hydraulic parts
GHP64 Brake Hose Front
010202 S/S Locking Ties
010102 2"x50’ Thermal Exhaust wrap, Beige
Polyester Felt Tape [3mm thick] (FELT-08): 2 in. x 50 ft.
JAGUAR E TYPE SERIES 3 REPAIR OPERATIONS MANUAL, Decent condition
File Type: pdf
Old Jan 29, 2025 | 08:20 AM
Valerie Stabenow's Avatar
Default Please provide year, model, body style ,etc
Looks like a great offering.. please provide the ID info...
Are you selling this as a 'lot' or willing to separate?
Old Jan 29, 2025 | 08:32 AM
SpecQra's Avatar
Absolutely willing to separate.
Old Jan 29, 2025 | 11:05 AM
Default and your E type was.....
Help us with the year and body style? I looked through your list... Series 3???
thank you!
Old Jan 29, 2025 | 05:18 PM
SpecQra's Avatar
We had a 1965 Etype Series 1 4.2L but bought a lot of Series 3 parts
Old Jan 29, 2025 | 05:30 PM
SpecQra's Avatar
[QUOTE=SpecQra;2820305]We had a 1965 Etype Series 1 4.2L
But bought a lot of parts for a series 3 v12
Old Jan 29, 2025 | 05:42 PM
SpecQra's Avatar
If interested let me know I have a pricing list of each part
Old Jan 30, 2025 | 10:31 AM
Default just add them?
Maybe just do an 'edit' on the list you posted above and add the prices next to each item??
Old Jan 31, 2025 | 07:36 AM
SpecQra's Avatar
Default Edited to included prices :)
Updated with prices and attached file with pics again
Description Quantity Available Unit price
Pair Kangol Seat Belt, Dark Grey with Stalk, As is 1 $250.00
Interior Rearview Mirror head 1 $45.00
Sidelamp LHF with bulb 1 $160.00
Retainer 5 $15.00
Headlamp Peak RH 1 $125.00
Wire Wheel Chrome Spinners, 2 Right + 2 Left + Spinner Removal Tool 1 $400.00
uni Syn Carburetor Synchronizer 1 $20.00
Vergaser Tester Synchrometer Carburetor flow meter 1 $50.00
Dash Legend Switch Strip (No Heated Rear Screen) 1 $20.00
De-mister Bezel Center 1 $40.00
De-mist Bezel outer 2 $30.00
Mounting Grommet 7 $5.00
Indicator Warning light Lens 1 $10.00
Handbrake Pawl Tension Spring 1 $5.00
Pulley washer 2 $5.00
Brake Reservoir Cap, Rubber 1 $8.00
Handbrake pawl 1 $8.00
Gaskets 6 $7.00
Fuel Tank Sender Unit Gasket 1 $7.00
Stainless Steel T-Bolt Hose Clamp 1.25" - 1.46" (32mm-37mm) 2 $10.00
50 Amp Fuse 2 $0.50
Bush upper wishbone 1 $25.00
Folding Luggage Hinge Boot Board 3 $15.00
Chrome 'V12' Boot Lid Badge / Script for E-Type Series 3 1 $15.00
Set Screw 3 $0.30
Oil Ring 1 $1.50
Handbrake adjusting nut 1 $9.00
Handbrake Adjusting bolt 1 $5.00
Switch 107SA On Off 3 $28.00
Pair of Floor Plugs 1 $10.00
Final Drive Seal/ Drive Axle Shaft Seal 1 $21.00
GRILL BADGE EMBLEM CAT FACE 1 $15.00
Breather Bung 1 $12.00
CLAMP FOR BREATHER BOOT 1 $3.00
PINION OIL SEAL FOR THE DIFFERENTIAL 1 $24.00
Glovebox handle 1 $25.00
valve keepers 2 $1.25
Breather Cap 1 $22.00
Cubby box lock and key 1 $30.00
E-TYPE HANDBRAKE RETURN SPRING 1 $3.00
Circlip 3 $0.75
Spiral binding 1 $3.00
Radiator Cap, NEW 1 $12.00
Radiator Cap, USED 1 $5.00
Screen pillar RH 1 $250.00
Pipe Clip, Balance Pipes 1 $8.00
Lockheed Hydraulic parts 1 $32.50
Brake Hose Front 1 $14.00
S/S Locking Ties 1 $5.00
2"x50' Thermal Exhaust wrap, Beige 1 $30.00
Polyester Felt Tape [3mm thick] (FELT-08): 2 in. x 50 ft. 1 $40.00
JAGUAR E TYPE SERIES 3 REPAIR OPERATIONS MANUAL, Decent condition 1 $100.00
File Type: pdf
Old Jan 31, 2025 | 09:54 AM
Thank you! Also post in Classifieds as there are other Jaguars that might share the part numbers.
Great work on inventory list, photos, prices!
Old Feb 4, 2025 | 06:27 PM
RedRider48's Avatar
BD332/5 Retainer
C386 Pulley washer
8836 Handbrake pawl
EBC10199 Gaskets
C13932 50 Amp Fuse
SH505051J Set Screw
EBC2552 Oil Ring
C44386 Breather Cap
C34360 Circlip
Why ASAP? Wanna offer your location?
Old Feb 5, 2025 | 05:50 AM
SpecQra's Avatar
GOod morning...no longer need parts because we no longer have the E. Located in Florida.
Old Mar 31, 2025 | 08:05 AM
SpecQra's Avatar
BD332/5 Retainer
SOLD BD20590 De-mister Bezel Center
SOLD BD20592 Demist Bezel outer
C386 Pulley washer
8836 Handbrake pawl
EBC10199 Gaskets
C13932 50 Amp Fuse
SH505051J Set Screw
EBC2552 Oil Ring
C44386 Breather Cap
C34360 Circlip
Few items sold
adenshillito
Sep 27, 2023 05:29 PM
aquatiteman
Apr 2, 2023 11:37 PM
jaggermang
Dec 12, 2020 05:24 PM
racerxf12004
E type ( XK-E )
Aug 20, 2019 09:43 AM
smith356
Apr 22, 2015 09:42 PM
