E type ( XK-E ) 1961 - 1975
fuel delivery > creating a vacuum
Old Aug 5, 2015 | 02:07 PM
RedRider48's Avatar
Default fuel delivery > creating a vacuum
Hey Guys,
Recently tried to fire up the 'ole E-Type after a long long 16 month nap. It fired quickly, ran for couple minutes and died.....
Diagnosis:
Fuel level is about a 1/4 tank. Ran the pump for 1 minute or 2,, the pump ran fast, as opposed to slow(er), as when under pressured. Noticed the glass filter bowl was not filling. Removed the fuel pick-up, all looked normal?
I discovered it does pump fuel, as I poured fuel into the pickup with the pump running and you could tell from the sound it was pumping and the glass bowl filled. However, it seems to lose this prime.
So, do I need to create a vacuum up front with the pump running to draw fuel, so as, to prime, you think?
Thanks for any thoughts...
Old Aug 6, 2015 | 08:00 PM
RedRider48's Avatar
Whelp, it's fixed! For all of those who follow in my foots steps.....
I removed the pump, to check the diaphragm, it was fine. There was another seal, beneath the following that was all askew on one side. Not sure what this seal is called.
Anyway, fixing it, cured the problem.
Attached Thumbnails fuel delivery > creating a vacuum-img_0656.jpg   fuel delivery > creating a vacuum-img_0657.jpg
Old Aug 8, 2015 | 10:49 PM
RedRider48's Avatar
Default on the road again.....
After fixing me fuel delivery problem, I placed a leash on the kitty and off we went....
www.youtube.com/watch?v=g85MOgo5fKc
toronadomike
Jan 22, 2026 10:13 PM
silkcat
Jan 18, 2025 04:29 AM
njburlington
Sep 22, 2020 07:03 AM
njburlington
Sep 24, 2015 08:40 PM
TheWarlock
Sep 20, 2015 03:22 PM
