E type ( XK-E ) 1961 - 1975
Jaguar E-Type 1970 Fuel Pump
Old Oct 14, 2018 | 10:51 PM
FrankieBoy's Avatar
Default Jaguar E-Type 1970 Fuel Pump
I have a 1970 E-Type with a Holley fuel pump that is very very loud. I noticed it was installed with only one nut and bolt directly to the body with a wire ...that I guess is the positive feed to the pump on the underside (the nut end). My mechanic told me that the Holley pump is very good....but this thing is so noisy it is ruining my driving experience. I was wondering if the SU pump is noisy? Is it reliable? Or, if I keep the Holley should I install it on a piece of rubber to isolate it from the body....always keeping that bottom wire etc grounded? Maybe even put some insulation in the body between the pump and the front compartment to deaden the sound? But with the nut and bolt still connected to the body on the underside I think it will not help. Could I even mount the pump off the body (on a piece of ply or maybe a block of plastic). Thoughts please!
Old Oct 15, 2018 | 06:34 AM
Coventry Foundation's Avatar
The correct pump and mount is isolated and you will only hear it with the key on and the engine off.
Old Oct 15, 2018 | 05:18 PM
FrankieBoy's Avatar
Thanks Cov Foundation. I grew up in Cov (hence the Jag in LA!). Quick follow up. You say the pump and/or pump mount is isolated, do you know how it is installed? Isolated from the body and frame? Just wondered. I think I am safe mounting a rubber "shelf" and then mounting the pump on it....stuff some insulation down the rear wing. Attaching pic...shows the pump and nut/bolt attachment ....if you could take a look and let me know your thoughts....thanks
FrankieBoy
Oct 15, 2018 12:38 AM
1970WillowGreen
E type ( XK-E )
Dec 6, 2015 07:25 PM
1970jaguar
May 26, 2009 06:07 AM
marinawazz
Aug 22, 2008 05:43 PM
