E type ( XK-E ) 1961 - 1975
keys
Old Nov 10, 2022 | 07:38 PM
egold56's Avatar
Default keys
I s the key to th glovebox the same key to the door of a 1974 xke
Old Nov 11, 2022 | 10:37 AM
Valerie Stabenow's Avatar
Default Keys,
on my Series 2, 1969 coupe, built August of 1969, I have a separate key for the doors and the 'glove box'... I looked for info indicating if there had been a production change, perhaps someone has that info.
Old Nov 12, 2022 | 03:52 AM
dibbyandco's Avatar
I'm the same as Valerie on my '69, separate key for the glovebox
Old Nov 12, 2022 | 10:33 AM
Default key photo(s)
And I forgot to mention , if you would like photos of the key 'heads', I can post those.
Here is a link to a fairly well-known British parts supplier, generally, IIRC, accessories:
https://triple-c.com/Jaguar_Replacement_Car_Keys.cfm
the ignition key for the Series 3 looks alot different than my Series 2, but not sure if anything was changed for the glovebox, and all my reference books remain silent.
Old Nov 12, 2022 | 12:42 PM
egold56's Avatar
I think the glove box and door key is the same. However my car sat for so long that I think the door locks are sticky. I will try to free them up and see if I can get the key to work.
Old Nov 12, 2022 | 03:53 PM
Default sticky
I had REALLY good luck this past month with my stiff right side door hinge. I tried WD, teflon lubricant, then bought a fresh can of PB blaster... That nailed it. see if you can get that little red pipe in the lock opening, then also spray some on the key itself and insert it and work it. If you can isolate the handle from the body.. a hair dryer might warm it up a bit, too.
davidsxj40
XJ40 ( XJ81 )
Oct 7, 2020 12:56 AM
Andrew Fitch
Apr 30, 2019 08:38 PM
66Jaguar
E type ( XK-E )
Mar 5, 2017 10:38 PM
ditenorio
Aug 5, 2014 10:17 PM
martyn812
Sep 26, 2011 07:14 PM
