E type ( XK-E ) 1961 - 1975
New tires for 73 e type Roadster
Old Mar 4, 2015 | 11:48 AM
bagaines2004's Avatar
Default New tires for 73 e type Roadster
I am looking to purchase a new set of tires for my 73 e type roadster. It currently has Michelin 225/70/15 MXV4 tires on it. I would like to find a good performing tire with good ride quality. Any recommendations?
Old Mar 6, 2015 | 04:48 AM
gatekeeper's Avatar
Unless there is a reason you want to switch brands, I would keep what is on it. Never had experience with the MXV4 tires on your particular vehicle but, have used them on Cadillacs and found them to be outstanding.
Old May 16, 2015 | 03:28 PM
Captbob's Avatar
I am also looking for tires for my 74 E type. Previous owner had Michelin 215 70R15 tubeless with tubes. Not what I want to do. I can't find tubed tires. What did you decide to do?
Old May 16, 2015 | 05:41 PM
bkeats's Avatar
The correct size is 205/70/15. One S3 I have came with 215/70/15 and breaks the bonnet gas strut if the steering is on full left lock.
Although the actual tire dimensions vary between manufacturers, the theoretical increase in rolling circumference between a 205/70/15 and a 225/70/15 is 88mm (3.46in).
Regards,
Brent
Old May 16, 2015 | 07:13 PM
Captbob's Avatar
I am aware of the correct size! I want to purchase tubed tires for my car. I have found 2 web sites, one in England and Lucas. Just wondering what people were coming up with. I see that some sites list a tube for a radial tire.
Old May 17, 2015 | 12:25 AM
Doug's Avatar
Originally Posted by Captbob
I want to purchase tubed tires for my car. .
Buy 'tubeless' tires and use tubes. I think it's pretty common....or used to be years ago, at least.
Old May 20, 2015 | 07:18 PM
Jagfixer's Avatar
Correct Doug. When installing tubeless tires on a tube rim, must use tubes. Coker Tire has both tube and tubeless. If you want radials, they will come as tubeless and you must mount with tubes. Coker Tire has an ask us on website and you will get an answer in 24 hrs. Verdstien tires come both ways too.
Old May 21, 2015 | 01:09 PM
Mr. Barry's Avatar
Make sure that all labeling is removed from the inside of the tubeless tire, when using a tube....In addition, the inside of the tire must be clean , and free from any roughness or debris...It takes very little to puncture the tube, when it rubs against the inside of the tubeless tire.
Finally, a little talcum/baby powder inside the tire, will reduce friction on the tube.
Edward
Old May 27, 2015 | 01:48 PM
jww427's Avatar
I just put on BFG radial TA
215-65-15
They fit well.
The wire wheels don't require tubes do they?
thanks
JWW
Old May 27, 2015 | 01:53 PM
jww427's Avatar
Default tires 72 xke
Oh, forgot to say I have a 72 OTS.
Many thanks!
John
Old May 27, 2015 | 04:24 PM
alfred's Avatar
they only need tubes if the rubber belt is leaking. I had 4 new tires put on, two were fine without tubes, two needed tubes. Find a tire place that know about wire wheels, they will likely have a tire tank to check for leaks.
Old Jun 7, 2016 | 07:48 AM
uras's Avatar
With the restoration on my 74 E-type almost completed, I am looking for replacement tires. Based on what I have gathered, the replacement should be Dunlop Acquajet 205/70/15's. I have not been able to locate a supplier in Ontario, Canada for this brand of Dunlop. Anyone have any suggestions?
Old Jun 18, 2016 | 12:46 AM
lrgridley's Avatar
The proper Dunlop ER70VR15 tires are available but they aren't cheap. With modern compounds they're far better than the originals and I think they just look right.
stanjag
Dec 29, 2024 08:26 PM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
