E type ( XK-E ) 1961 - 1975
Series 2 hazard flasher relay location?
Old Mar 25, 2018 | 02:15 PM
Mr. Barry's Avatar
Thumbs down Series 2 hazard flasher relay location?
I think my hazard flasher relay has gone bad....All bulbs are good, and switch works, but only the driver side flashers work...I'm thinking the flasher is bad....Car is a Series 2 OTS.
I don't know where it's located...help.
Edward
Old Mar 26, 2018 | 11:46 AM
Mr. Barry's Avatar
No One?
Old Mar 26, 2018 | 12:54 PM
gtjoey's Avatar
I had many and drove a gagillion miles in my green car.
Take the lenses off the blinkers an add a ground clip to the bulb holder.
Or just ground out the casing
VERY COMMON.
1. Say drivers side works, leave it alone.
2, go to other side remove front and back lenses, you said the bulbs were good?
Ill bet its a ground issue..........
Not a flasher
p.s. do not use electronic flashers, micro flasher or led. They wont work right.
Good luck!
GTJOEY1314
Old Mar 27, 2018 | 01:31 PM
Mr. Barry's Avatar
Joey
Thanks for the reply....I agree it's probably a ground issue...Will try as you suggest....
Edward
Old Mar 30, 2018 | 01:58 PM
enderle's Avatar
On my series 2 the flasher is located just behind the center gauges between the two fuse banks. It plugs in and has a three prong plug.
Old Mar 31, 2018 | 01:59 PM
Mr. Barry's Avatar
I did find it , o.k...Problem now is if it is the problem...I'm waiting for the new one to show up from SNG...I bought some new lens seals, so I will check the sockets when the new seals are installed.
Edward
Old Apr 1, 2018 | 10:01 AM
gtjoey's Avatar
A little of both you will get it, the rear has those bullet connectors to a clip for grounding, if you moved stuff around sometimes its the trick.
If its blinking on one side its usually not the flasher but for the couple of bucks you have insurance.......good luck
gtjoey1314
Old Apr 2, 2018 | 08:43 PM
billb44's Avatar
The hazard flasher is common to all 4 bulbs and is not very likely the problem. Nor is the flasher switch. Since the signals work, a ground problem is also not likely. I believe you will find that it is the hazard dash switch or the connections to it. I would start by cleaning the connections to it and use some contact spray cleaner.
If you remove the radio console, the fold down dash panel will open much further making access easier. Good luck.
Old Apr 3, 2018 | 10:49 AM
Mr. Barry's Avatar
The hazard flasher bulbs and sockets are separate from the turn signals on my car...I really don't think the problem is the flasher relay, either....I am thinking it's a corroded or loose connection on the passenger side....Still waiting for the SNG order with my new lens gaskets, since I don't want to take the lites apart twice...Not sure why SNG is taking so long to send such a simple order....Next time I'll call, instead of internet order.
Edward
davemack
May 22, 2019 06:11 AM
Jagicon
Dec 4, 2017 11:26 AM
jagnoob
XJ40 ( XJ81 )
May 2, 2014 12:20 PM
Aviator-Olav
Apr 2, 2014 07:58 AM
marvin1960
Jun 1, 2013 08:30 PM
