E type ( XK-E ) 1961 - 1975
Series 2 OTS windshield stabilizer questions
Old Mar 11, 2016 | 01:00 PM
cdnp62000's Avatar
Default Series 2 OTS windshield stabilizer questions
I have obtained the brackets and screws required to install the sun visors on my car as well as a series 1 mirror that attaches to the stabilizer rod.
When my dad had the car refurbished in 2008, the shop attached the top of the windshield to the stabilizer rod top block with a bolt and nut.
The series 1 mirror I bought does not slide down the existing stabilizer rod, and looking at the top block, it is not tapped for screws, just a clean pass through hole.
Are the series 1 and 2 stabilizer rods supposed to be the same, so I should be able to install the series 1 mirror?
Did the series 2 sun visor brackets and windshield attach to the block with screws or a bolt?
Thanks for any assistance.
Roy
Old Mar 20, 2016 | 06:28 PM
felinecat's Avatar
If the top bracket has the usual non removable top socket, then lower the center dash section and undo the two screws that hold the bottom of this rod to the base of the windshield, now remove the whole rod and undo the two nuts on the bottom of the rod, slide the mirror on and replace........
Old Mar 20, 2016 | 09:31 PM
cdnp62000's Avatar
Thanks for the reply. Top bracket is removable but mirror hole is too small for rod to go through. I have ordered a new rod and top bracket as the bracket on the car is not tapped for the sunvisor screws. Hopefully will all go together properly.
QUOTE=felinecat;1425896]If the top bracket has the usual non removable top socket, then lower the center dash section and undo the two screws that hold the bottom of this rod to the base of the windshield, now remove the whole rod and undo the two nuts on the bottom of the rod, slide the mirror on and replace........[/QUOTE]
3434char
Mar 20, 2016 08:48 AM
fotontom
Mar 13, 2016 09:14 AM
frank james
Mar 13, 2016 01:45 AM
powerhouse
Mar 12, 2016 12:17 PM
Uncle Fishbits
Mar 11, 2016 10:53 AM
