E type ( XK-E ) 1961 - 1975
Tire Question for 15x6 rims for Etype S2
Old 09-23-2015, 12:55 AM
Ol Blue's Avatar
Default Tire Question for 15x6 rims for Etype S2
I have purchased new dayton 15x6 rims and dont know where to go for tires. I want to have a little more tread. Hence why I purchased the wider wheels. Can anyone recommend a wider tire that looks of the period, preferably with the red strip, but doesnt rub. Will a 205x70x15 work well? Much apreciated in advance
Old 09-23-2015, 09:47 AM
SCMike's Avatar
I have 205-70/15 tires on 6" rims on my Series 1, and they work perfectly fine. Lots of others report the same. It's all personal preferences, but the red stripe tires were never standard issue on E-Types (if you show up at a JCNA concours with them, they are major point deductions) - I have never liked them, but that's just me. Much easier/cheaper to go with black sidewalls.
With wire wheels, there is always the issue of tire tubes or not. I avoided that by going to Realm D-style knock-off alloy wheels. So I am not up to speed on the current status of tubes or not.
Ol Blue (09-23-2015)
Old 09-23-2015, 12:34 PM
Ol Blue's Avatar
Great thanks. I am thinking michelin xwx
Old 09-23-2015, 02:48 PM
Fraser Mitchell's Avatar
Received 2,435 Likes on 1,941 Posts
As I remember it, the V12s had the wider tyres as fitted to the V12 saloons (215/70VR15). However, the wheel arches were flared out so these might be borderline, but the 205s should be OK
Old 10-04-2015, 10:57 AM
RedRider48's Avatar
Hi,
I run Michilin HydroEdge directionals. Although, never really tested in the wet, the dry sure is fun to push. These are mounted on Dayton 15X6s.
Old 01-08-2016, 07:14 PM
felinecat's Avatar
Dayton sells several types of 6" rims for E types if you choose just a 6" instead of the original 5" (series 1 2) the rim is only 1/2" wider on the inside and 1/2" wider on the outside! so this is no problem with 205s...........but if you buy the center laced 15 x 6" rims
the outside edge of the rim is 2" out further than stock and the inside edge is 1 1/2" toward the outside of the car. I have these, I use 215 x 15" x 60series tires with the rear bump-stops removed. No problems with fast driving !
piper 888 (05-08-2022)
Old 01-09-2016, 06:12 PM
stremsjg's Avatar
I replaced my Michelin red line tires this summer with Vredestein 185 X 15 on my '66 Series 1 XKE 2+2. The ride is much softer than the old Michelin's and I would recommend this tire in blackwall for your car. Cost was $915.00. See pictures below.
Tires at Discount tire. They would not mount the tires for me since the car had knock off wheels
Label on the tire
My '66 E-Type with the Vresestein's mounted.
Old 01-17-2016, 11:17 AM
Mr. Barry's Avatar
I have always liked the 185's...My car came from the PO , with 205 70's...They're too expensive and new, to replace, now, but I can tell you that there is a lot less room to remove them from the rear hubs, and they don't come out of the spare-tire well easily, either....Even 195's would be better, than the 205's....
I think steering effort is higher with the 205's (unless you have power steering, of course).
Edward
Old 01-19-2016, 12:25 AM
AHudson's Avatar
I have 205/70s on 6" rims. To my eye, fits the wheelwells nicely, tucked in enough but more rubber on the ground than stock. They do require some angling to get the rears in and out on the occasions you'd need to do that. My spare is an 185/70 just to keep things tidy in the boot.
Old 05-06-2022, 08:39 AM
dtivey's Avatar
I have 15 x 6.5 centre laced rims and am going with your recommendation of 215-60 series tyres. Do yo think I will have any fitment or rubbing issues using these front and rear.
Also, do you have any other feedback that you can give me, such as low speed steering etc.
Thanks,
Dave
Old 05-07-2022, 05:57 AM
mikemilton's Avatar
This shows the fit of 215-60s on a series one
215 60 15 tires on a series one
The following 2 users liked this post by mikemilton:
joe kelly (08-03-2023), NatGarrison (08-15-2022)
Old 06-26-2022, 07:55 PM
MrVette's Avatar
What is the largest tire that will fit in the series 2 spare wheel well? 195 or 205? Would it matter if the wheel is 5" or 6"?
Old 06-26-2022, 08:13 PM
Daytona's Avatar
Ol Blue,
If you are looking for period looking tires, go to Coker tire (Coker.com I think) company based here in the US. I also just recently learned about https://www.longstonetyres.co.uk in the UK. Apparently many jag guys in the US are buying their tires from longstone. The tires are cheaper, greater choice of tires, and it costs only 60 pounds to ship the tires to the US. Also everyone that I have talked with that has decided to go with wider tires, they all have kept the spare stock size so it will fit in the boot.
Good luck and let us know which way you decided and how it turned out.
Bill.
Old 06-29-2022, 04:43 PM
XLRateMe's Avatar
My two bits. I have 205 Michelin Defenders on 15 X 6 wires. Very smooth and quite at both city and highway touring speeds. A couple of other E-Type owners in the club also have mounted the Michelin Defenders. They, too, are quite satisfied. (There is a guy who authored a book about his E-Type; he had Defenders with the lettering shaved off.)
Old 06-29-2022, 06:04 PM
Daytona's Avatar
Not to heavy a steering during Parking? I ask this because My wife will be driving the car.
Thanks.
Old 06-29-2022, 06:34 PM
XLRateMe's Avatar
I've never had to parallel park my E-Type. No trouble in regular parking; in or out. I am a small 5'3" guy. I actually have fabricated a rest pedal for my left foot to give me more support while driving. My own wife has no interest in driving my Jag.
If you are a member of a Jaguar club, or if not, contact the nearest club and test drive a similar E-Type to yours that has tire sizes you are considering.
Come on over to Plano, TX, and I will hand you my keys!
Old 06-29-2022, 07:06 PM
Daytona's Avatar
That is a generous offer, but I am a bit of a drive from you.
There are few E-Types in my area and I see them very rarely. I will pay closer attention next time I come across one of them, and check on the tire size. Maybe get a ride in it.
Thanks.
Old 08-15-2022, 03:43 PM
NatGarrison's Avatar
Mike,
What width wheels do you have? I have a '71 Series 2 FHC and I'm looking at upgrading my wheels to 6.5 inch wide one and was trying to figure out what size tires that I could use. The 215/60R15's was what I was wanting to try, but I wasn't sure if they would maybe be too wide. Also what size spare wheel and tire do you have in your boot.
Your red Series 1 really looks good.
Old 08-20-2022, 12:48 PM
XLRateMe's Avatar
I have 6.5 inch wheels with 205 70 15s. No issues. These wheels and tires will not fit in the spare tire well. My spare is the stock 185s.
Old 08-20-2022, 04:58 PM
MrVette's Avatar
Speaking of stock...I have an unused vintage spare I don't need, It is a narrow whitewall, 185V15 Dunlop SP Sport, tube type, rayon radial, made in Great Britain. Someone might need this for a concours class spare. The date code indicates it was made the 18th week of 1974.
Salem1
08-30-2020 11:27 PM
JTC3400
07-12-2015 08:01 PM
jahummer
03-19-2015 07:28 AM
vincent661983
11-05-2012 10:05 AM
drevenak
10-07-2010 08:27 PM
Quick Reply: Tire Question for 15x6 rims for Etype S2
