E type ( XK-E ) 1961 - 1975
XKE brakes
Old Jul 2, 2010 | 05:34 AM
Fraser Mitchell's Avatar
All the parts you need to rebuild the E-Type (XKE) brake system are available, (at least here in the UK). Most UK suppliers trade on the internet and will send parts to the US; there will also be US-based suppliers as the car is such a popular classic.
I would also suggest you replace all steel brake pipes with cupro-nickel, (called Kunifer) and brass fittings so corrosion is prevented. These are available already made up correctly. All threads on the system will be Imperial, not Metric so take care when purchasing.
Old Jul 28, 2015 | 02:42 PM
felinecat's Avatar
Being as 69s are series 2 cars with the best type of xke brakes and your car has sat for so many years the master cylinder, vacuum tank, activation cylinder, bellows booster, and all that other stuff, ( resevoirs, lines and the fittings) could all be upgraded to a simple more efficient system.........see e-type brake activation.............
Rivguy
Dec 4, 2020 07:55 AM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
SCMike
Sep 22, 2015 07:34 PM
etypo
E type ( XK-E )
Sep 22, 2015 10:33 AM
