F-Pace (X761) / C-X17 2016 - Onwards
Blown 35t 2017 S
Old Oct 3, 2022 | 11:25 PM
Paldi's Avatar
Default Blown 35t 2017 S
I have an opportunity to purchase one with a seized engine. Do you guys think it would be easy to swap in a new motor or rebuild it?
Old Oct 4, 2022 | 02:28 AM
Welcome to the forums Paldi,
The description 'seized' covers a lot of possibilities from timing failure to a rod hanging out of the side of the block.
The easiest and most cost effective solution would be fitting a good 'used' motor of the identical specification. To rebuild as a DIY project is very expensive in parts alone and a professional rebuild would inevitably make the project considerably more costly than buying a good vehicle instead. Another complication is Jaguar inventory has never recovered since the pandemic lockdown and more parts are becoming unavailable.
Old Oct 4, 2022 | 08:43 AM
Paldi's Avatar
The service rep I spoke with said the motor overheated due to a coolant leak. It was towed from the dealership to the auction.
Old Oct 4, 2022 | 08:55 AM
Paldi's Avatar
Thanks for the warm welcome and helpful suggestion. I'll be on the prowl for a used 35t motor from a wrecked S.
Old Oct 4, 2022 | 08:56 AM
Paldi's Avatar
I wonder if there is one for sale on this forum?
Old Oct 4, 2022 | 01:35 PM
Originally Posted by Paldi
.....the motor overheated due to a coolant leak. It was towed from the dealership to the auction.
The kiss of death to an aluminium Jaguar engine.
Old Oct 4, 2022 | 05:31 PM
Paldi's Avatar
I see used 35t motors on eBay for about $8,000 with 50k miles or so. $11,000 for "stage 2" rebuilt motors. I'm wondering what it might cost for labor?
Old Oct 18, 2022 | 07:54 PM
Paldi's Avatar
If I was to ask the dealer to put the car up on a lift, would the underside of the motor and transmission be visible or is there a splash tray of some sort that needs to be removed first?
Old Oct 19, 2022 | 08:28 AM
You will see nothing from underneath with the Undertray in position:
There's a lot of bolts but it only takes around ten minutes to remove it:
Old Oct 19, 2022 | 07:41 PM
Paldi's Avatar
Thanks, I will ask the seller to let me take a look, since they will not permit me to take it to a nearby Jaguar dealership to have it checked out.
WLS317
Aug 1, 2021 11:52 AM
darrhel
May 25, 2020 12:33 PM
Busa
UK & Eire
Feb 18, 2017 10:18 AM
Nati
Apr 16, 2016 06:23 AM
