F-Pace (X761) / C-X17 2016 - Onwards
Check engine light
Old Jan 16, 2026 | 11:01 AM
Tatertot77's Avatar
Default Check engine light
Hey! My 2017 f-pace 35t had the check engine light come on this morning. Took it to o-reillys’s and this is the code that came up (p2187) which is the code for the air intake hose not allowing enough air in the engine? Does anyone know if this is something that needs to be taken to the mechanic to be fixed or can parts be purchased and fixed myself? Any advice would be appreciated!
Old Jan 16, 2026 | 11:41 AM
NBCat's Avatar
Take the vehicle to a Jaguar main dealer or independent Jaguar specialist for diagnosis.
Here is a definition for DTC P2187:
https://www.dtcdecode.com/Jaguar/P2187-00
Old Jan 20, 2026 | 12:04 PM
RoverJoe's Avatar
Community Influencer
Air leak somewhere most likely. If you don't know how to diag it yourself, take it to a mechanic. Not something you want to start throwing parts at.
Old Jan 21, 2026 | 11:14 AM
2018XF25T's Avatar
One of the causes:
"Mass air flow sensor contaminated." Do this first before going to a mechanic, clean by spraying MAF Sensor Cleaner. It's Easy. There's ton of "how to do it" on YT. Go to the auto shop where you had it scanned and clear code. Then drive as you normally do and observe if the CEL comes back. If it does not, then you solved the problem
Old Jan 21, 2026 | 11:02 PM
RoverJoe's Avatar
It's never that simple, unfortunately.
Old Jan 30, 2026 | 04:14 PM
Tatertot77's Avatar
well update a coolant line just busted and is leaking a major amount of fluid so I wonder if the air leak was from that. If it’s not one thing it’s another with this vehicle :/
abel6532
Mar 23, 2026 10:11 AM
Marli G
Mar 12, 2025 08:23 AM
JDog
May 8, 2022 07:19 AM
erc1234
Aug 16, 2017 02:59 PM
magnum454
Apr 11, 2014 10:02 PM
