“Brake” warning light plus other warnings??
Old Jul 4, 2021 | 02:28 PM
Philipintexas's Avatar
Default “Brake” warning light plus other warnings??
2014 F-type S. 19,400 miles.
Periodically, starting with day one, I will receive the following warning lights;
“BRAKE”
“Stability control not available”
“Emergency brake assist not available”
I‘ve been to the dealer several times, they turn the warnings off but they will come on sometimes a year apart. I verified the master cyl. is full.
Does anyone know the cause of these warnings? Can I do anything to prevent them??
Old Jul 4, 2021 | 04:28 PM
scm's Avatar
scm
First thing to ask is how's your battery? Low voltage can give rise to spurious faults, so it'd be good to eliminate that first.
Old Jul 4, 2021 | 11:14 PM
DJS's Avatar
DJS
…and is it the original battery? The original battery was going strong in my 2014, but I replaced it last spring, figured 7 years was enough.
Old Jul 5, 2021 | 12:12 AM
sov211's Avatar
Your symptoms, as others have suggested, are caused by low battery voltage...
Old Aug 23, 2021 | 10:02 AM
Once again, I’ve replaced the battery, fully charged it(12.75V), loosened ground & hot connections, cleaned & replaced. I’ve gotten this occasional warning off & on since the day I brought the car home! Been to dealers several times and I still have the light.... Does anyone have a possible solution (Other than poor ground or bad battery)?
Found this un-connected wire near the positive end of the battery.. Can anyone identify it? Can’t find a spot for it...
Old Aug 23, 2021 | 11:30 AM
scm's Avatar
scm
I think that plug is used for initial tranportation and serves no purpose in a running car. Another hope dashed - sorry!
Old Aug 23, 2021 | 12:42 PM
Thanks....
Took a short drive and the damn thing healed itself again! But, then again, it’s English.
Old Aug 23, 2021 | 12:49 PM
scm's Avatar
scm
Originally Posted by Philipintexas
Thanks....
Well, which would you rather have, a self-driving car, or a self-healing car?
garethashenden
Oct 20, 2020 01:07 PM
Duke85
Jun 21, 2020 01:26 AM
Seakiwi
Dec 5, 2012 03:15 PM
