14 V6 Ftype side skirts
Old 10-19-2014, 05:30 PM
dmb1621's Avatar
Default 14 V6 Ftype side skirts
i have a 14 ftype v6 380 hp convertible, i like the side skirts on the v8s, looked in all accessory catalogs with jag, where can i buy them and how much? help!
Old 10-19-2014, 06:01 PM
GGG is offline
Received 16,816 Likes on 12,176 Posts
Welcome to the forum dmb1621,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to F-Type forum. Members here with the same model will be able to help.
Old 10-19-2014, 06:10 PM
lunagry's Avatar
Banned
what side skirts? are you talking about the design pack?
Old 10-19-2014, 09:29 PM
Foosh's Avatar
Received 1,026 Likes on 854 Posts
Yes, he is, but only the trim pieces that fit on the bottom of the rocker panels. I like them too. The rest of the "design package" is not of much interest.
Old 10-20-2014, 08:13 AM
ftypeguy's Avatar
I wanted these as well and investigated them when I got mine last year. The parts cost $1800 plus paint and install. A little pricey for me but if you find them cheaper please share as I love the look also.
Old 10-20-2014, 10:40 AM
gleonjr's Avatar
My dealer said they are not sold separately? If someone finds them...please share information as I'd like to add them as well.
Old 10-20-2014, 12:35 PM
ftypeguy's Avatar
if you do a search my old post about a year ago has the part numbers listed I just dont know how yto find the post but it is all broken down in there.
Old 10-20-2014, 03:16 PM
DJS's Avatar
DJS
DJS is online now
Received 2,074 Likes on 1,378 Posts
https://www.jaguarforums.com/forum/f...nsions-107953/
If you click on your screen name, there's an option to see all of your previous posts.
Old 10-20-2014, 04:46 PM
ftypeguy's Avatar
Item numbers refer to the above diagram in post #2.
5.0 Litre Supercharged
Item 1 - Body Side Moulding
LH Sill : T2R10396
RH Sill : T2R10395
Item 3 - Mounting bracket (Front)
LH : T2R3969
RH : T2R3968
Item 4 - Mounting bracket (Rear)
LH : T2R3971
RH : T2R3970
Item 8 - Finisher Panel
LH Sill : T2R3565
RH Sill : T2R3564
there you go hope it helps let me know if you find these at a good rate
Old 10-20-2014, 04:50 PM
ftypeguy's Avatar
Old 10-20-2014, 04:54 PM
ftypeguy's Avatar
let me know guys thanks
Old 03-17-2015, 11:28 PM
JMichael_LA's Avatar
Has anyone tried to just buy and add the "Finisher Panel" on each side? They are $383 each, and I'm assuming it's just a couple bolts and washer to fasten them. I'm seriously considering ordering them and seeing if they will just bolt on my V6 convertible
Old 03-19-2015, 01:10 PM
spinningbull's Avatar
I just replaced one. While the cost for the part is 400, it's not as simple as you'd think to add. The bolts are blocked by the paneling under the car, so you have to pull all that before you can replace the skirt
All told, cost me around 800.
Old 03-19-2015, 01:55 PM
hardwired's Avatar
the parts department at San Jose British motors told me that if I wanted the finisher panel in the same color as my car, I would have to get it painted. they quoted me $225 each if I remember correctly.
supposedly it's current coating is primer.
danke
03-03-2016 10:57 AM
Mbourne
09-14-2015 09:21 PM
christophcr11
09-14-2015 08:38 PM
diablomkii
09-14-2015 02:37 PM
avern1
09-08-2015 06:25 PM
Quick Reply: 14 V6 Ftype side skirts
