2 Misc Questions (Fuse + Windows)
Old May 17, 2016 | 08:31 PM
2015Coupe's Avatar
Default 2 Misc Questions (Fuse + Windows)
I've been meaning to post these questions for a bit now, but have been incredibly busy, and these two quirks have been driving me nuts.
Put the R in storage for the winter. Warm weather finally appeared, took the R out, and 2 things are happening that I don't recall seeing before I put her away.
- My iPhone 12V charger (cigarette lighter) doesn't work in either of the two spots. Confirmed the charger works in other cars, and charges if I just plug in the USB part of it into the USB ports. But...if I use the car charger part, it doesn't work. Is there a fuse specific to these lighter ports? (The charger is a two piece USB cord + cigarette lighter part.)
- My drivers side window is one-touch up AND down. My passenger side window is one-touch down, but you have to hold the button for the duration of the window going up. Is the passenger side not one-touch up? I don't remember from before winter, but I feel like if it wasn't that's something I would think is quite unusual for a vehicle at this price point (as I'm thinking now). In Mercedes' I've had in the past, sometimes you had to re-program the windows (re-teach them the up and down for the one-touch). Not sure if that's also a Jaguar thing?
Old May 17, 2016 | 09:14 PM
Unhingd's Avatar
The answer on the lighter ports is yes. There is a dedicated fuse. The locations for the 2016 fuses were posted on another thread recently.They are different for 2015,
Yes, you can reprogram the windows. Hold the button in the down position for the entirety of the window travel and for another 3-5 seconds after it gets to the bottom.Do the same in the up direction. Should solve the problem.
Old May 17, 2016 | 09:24 PM
2015Coupe's Avatar
Will give it a try, thanks.
Old May 17, 2016 | 09:29 PM
Unhingd's Avatar
The fuse panel you are looking for is the fuse box under the carpet in the passenger foot well. F52 is for the socket in the center console and F53 is for the socket in the cubby (glove box).
Fstbmw1
Apr 9, 2016 08:42 AM
MarkC123
Apr 2, 2016 07:51 AM
rsq911
Apr 1, 2016 11:23 AM
cbornet
Mar 30, 2016 08:35 AM
Jagjagplayingup
Mar 29, 2016 03:11 AM
