2014-2017.5 F-TYPE CarPlay Upgrade
Old Mar 26, 2026 | 08:50 AM
  #121
Carbuff2's Avatar
K-Mart???????????????
Ask the producer of your unit if you can load your own boot logo or splash screen. Then you could choose a Leaper or Growler.
I know. decisions decisions...
Old Mar 26, 2026 | 05:47 PM
  #122
Tayls77's Avatar
I know K-mart not really worried about the boot screen its usually gone by the time I have backed out of the garage
Old May 8, 2026 | 02:44 AM
  #123
Kuhli's Avatar
Hello,
I’ve had the CarPlay module for a year now and am very satisfied with it.
However, one thing that annoys me a little is that during a drive of about 200 km, CarPlay switches back to the car's main menu at least 10 to 12 times, and I have to tap it again to reopen it.
This is particularly annoying, for instance, when you are using navigation.
Has anyone else experienced this?
Best regards, Frank
Old May 8, 2026 | 05:49 AM
  #124
Tayls77's Avatar
I have not had that and taken the car from Ontario to North Carolina and back, the only issue I find is that if I stop for gas I often have to disconnect and reconnect the phone to get the music to play.
Old May 8, 2026 | 08:49 AM
  #125
Carbuff2's Avatar
THAT might be a function of the car's head unit.
I've noticed that the display resets to the 'home screen' after a few minutes (the time can be adjusted in the car's SETTINGS but not eliminated that I can determine.
Anybody else?
Old May 8, 2026 | 09:51 AM
  #126
Adam Deermann's Avatar
I had a similar problem with a carplay unit (different car), it was the wifi connection. I mounted it in a different position and it was super stabble. Maybe something to look at.
regards,
Adam
Old May 8, 2026 | 09:02 PM
  #127
AlexJag's Avatar
Sponsor
Anyone done 2018+ F-Type?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old May 9, 2026 | 03:51 AM
  #128
MajorTom's Avatar
Yep, UAD have a unit for MY18 cars with the 8" screen. Another option is to install the 10" OEM screen with the OEM software updates but that's pretty tricky. There are some threads about both options.
Old May 9, 2026 | 09:41 AM
  #129
Kuhli's Avatar
Anybody else?
Thanks a lot, that seems to have been it.
It's running through perfectly now.:-)
I also went ahead and connected the phone via cable this time.
Frank
Old May 15, 2026 | 04:57 AM
  #130
Brachacz's Avatar
Hi
Anybody else fitted new mr12v P3000 carplay/android auto?
Search for "Jaguar XJ F-type XFR Wireless CarPlay Android Auto MOST Interface", on their page or in google and append mr12v
I pulled the trigger since in my XK it worked beautifully, took me 1h for research on disassembly and 2h for the job.
Everything works (music, calls, rear camera, switching between oem system and AA) except steering wheel buttons.
Most likely there's something wrong with canbus decoder profile
- short press prev/next track tries to select prev/next tv channel instead of controlling music in android auto
- long press "prev" on steering wheel -> brings up Google assistant (gemini),
- long press "mode" on steering wheel -> “next track" in Android Auto but also triggers cycling through media sources in the car (it's what usually "mode" button does)
Did anybody get that working? So far (a week) I wasn't able to get a response from manufacturer.
Old May 18, 2026 | 12:03 PM
  #131
Simonusa0's Avatar
As WhiteTardis said for module location . However you will need to get the wiring back to the unit in the center behind the seats.... easy if it's a coupe ...more involved to get to if its a convertible like mine. Also the I needed to unwrap some of the loom circled yellow to make it longer and gain 8" then wrap up the exposed wires ... result is the shown in white circled photo.
Old May 18, 2026 | 01:50 PM
  #132
eeeeek's Avatar
What was your trick for getting the hoops (whatever thcrash bars behind the seats are called) out?
Old May 18, 2026 | 03:07 PM
  #133
graybeardnw's Avatar
FF into about 4:50
Old May 23, 2026 | 01:51 PM
  #134
Simonusa0's Avatar
Here ya go ..from the workshop manual.
File Type: pdf
DiogodaSilva86
Jun 17, 2024 07:23 PM
Brock
Apr 24, 2024 05:56 AM
clarets
Jan 25, 2024 09:06 PM
Simonusa0
Nov 5, 2023 03:11 PM
Jape
May 2, 2023 02:19 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
