2014 V8 S - how often to change the Diff And Trans Fluid??
Old Oct 9, 2020 | 01:26 PM
mchums's Avatar
Default 2014 V8 S - how often to change the Diff And Trans Fluid??
my 2014 has 48k on it. I know there's some diff issues with the f-types but changing the fluid is not on the maintenance schedule at 48k. How often are people recommending to change these?
thanks!
Old Oct 9, 2020 | 03:01 PM
HHarry's Avatar
I think the diff fluid is on the 7 year service, so you’ll be due soon. Some of the DIYers are doing it every 10k.
Not sure about the trans fluid.
Edit - 8 year service, not 7.
Old Oct 9, 2020 | 03:45 PM
scm's Avatar
scm
I've checked the service sheets for my MY18 and the transfer box fluid should be done every 3 years, the rear locking diff every 4 years. At 9 years the front diff and auto box fluid should done.
Old Oct 9, 2020 | 09:01 PM
mchums's Avatar
sounds good, thanks. I'm going to go ahead and do them both while I have it up on the racks. any tricks/nuances I should know about doing them on the f-type??
Old Oct 9, 2020 | 09:38 PM
Therock88's Avatar
I put together 2 DIYs on this forum that may help you...
Good luck,
DC
Rear Here
Front Here
Old Oct 10, 2020 | 12:41 AM
DJS's Avatar
DJS
Taking mine in for next month for a supercharger snout, plus preventative stuff. Dealer is ok changing the diff fluid, but said they don’t normally touch the transmission unless it’s leaking. (65k miles, 7 years.)
Old Oct 10, 2020 | 07:24 AM
Paul_59's Avatar
Banned
ZF recommend the semi synthetic Lifeguard 8 fluid used in F Type auto transmission is changed after a maximum of 150,000 Km (93,000 miles) or in more severe duty (high loads and temperatures) 100,000 Km (60,000 miles)
Old Oct 10, 2020 | 12:17 PM
mchums's Avatar
ok cook, sounds like I can hold off on the Trans. Definitely get the diff done.
Thanks all - and damn, what a great DIY @Therock88 !!
Old Oct 10, 2020 | 12:29 PM
Therock88's Avatar
Thanks. Hope it helps.
DC
ArnoldKay
Mar 29, 2022 03:43 AM
tkwesa
Sep 26, 2020 03:05 AM
David Meier
Sep 15, 2020 05:30 PM
MikeLss1
Aug 23, 2015 02:03 PM
Spurlee
Jun 27, 2013 06:48 PM
