2015 F Type Base
Old Dec 6, 2020 | 06:38 AM
Iandallas's Avatar
Default 2015 F Type Base
Anyone else out there with a base v6 model? Recently purchased and want to avoid any problems.
Old Dec 6, 2020 | 07:27 AM
Carbuff2's Avatar
No complaints (aside from giving up on the the crappy Sat/Nav) on our '14 base model, after 2.5 years of ownership.
What options does yours have? (Look on TOPIX)
Ours was heavily optioned from new ($12K-worth).
Old Dec 6, 2020 | 07:47 AM
Iandallas's Avatar
What did you switch your Nav to? I was playing around today with the in car apps and wasn't too thrilled about it.
As far as options I have everything except active exhaust and ambient lighting choices.
Old Dec 6, 2020 | 09:12 AM
Carbuff2's Avatar
Waze or Google Maps.
I haven't done this yet, but there are multiple topic here about upgrading head units to CarPlay and Android Auto.
Old Dec 6, 2020 | 11:19 AM
SinF's Avatar
Welcome to F-type ownership. F-type base is really good value, as all V6 have the same engine hardware only base running detuned. The only downside to tuning for more is that base does not have a limited slip differential, so with more power you will end up with more one-wheel burnouts...
F-type shares a lot of mechanics with earlier Jaguar XKR, even early F-types benefit from 'mid cycle' mechanical updates and are considered reliable. As no car is perfect, there are few common themes and re-occurring flaws that you will have to deal with.
Issue 1: Cooling system and plastic coolant piping - unfortunately a number of plastic coolant pipes in the engine bay were made from material that becomes brittle with age and splits at the seam. This was made worse by adding an insulated engine cover that traps heat in the engine bay. Some of these coolant pipes are in the engine valley, requiring removal of supercharger to replace. Parts were updated around 2017 to seam-less design to prevent splitting, but your F-type does not have them installed from the factory. These can fail two ways - sudden failure where you dump all coolant and overheat the engine or slow leak. Sudden coolant loss is more dangerous as in-dash engine temperature indicator displays a running average and not instant engine temperature measures, delaying when the driver notified about overheating. So by the time you see the dash warning about overheating the engine have been cooking, potentially without any coolant at all, for a few minutes. Treat anything related to cooling system as an emergency, do not wait to pull over, shut the engine off, and open the hood. If you get coolant warning, have the car towed unless you can confirm it still has coolant. While this might be an overkill, I also ask my garage to pressure test cooling system every year prior to storing it for the winter. Additionally I permanently removed engine cover and it had measurable effect on reducing engine bay temperature.
Issue 2: Engine oil and sludge. AJ133 V8 and AJ126 V6 engines in F-type use direct injection (DI). DI means these engines are prone to developing sludge on intake valves if oil is neglected. These engines also use oil pressure to control variable timing. All of this means that things go bad very quickly when the oil gets dirty. Fortunately, frequent oil changes using spec oil shown to largely mitigate sludge. It is very crucial that you stay on top of oil changes and use spec synthetic oil with specified additives. Also keep in mind AJ133 V8 doesn't have low oil pressure sensor (yes, you read it right), this means you can run the car dry and it will not warn you. All of this means that you have to be religious about changing oil and monitoring engine oil level.
Issue 3: Injectors. AJ133 V8 and AJ126 V6 engines in F-type use direct injection (DI). This system has two stage fuel pumps and high-pressure injectors. This setup means that running out of gas has a chance to damage pumps, so take care not to do that. Injector failures are unfortunately known to happen where the whole rail has to be replaced, but can be mitigated with regular use of PEA-containing injector cleaning. I recommend running PEA fuel additives like BG 44K annually or budget for injector replacement in a couple years.
Issue 4: Battery and charging. When you plug anything into OBD port, power management control module is known to get glitched and not completely power the car down. This in turn runs the main battery flat as the car never fully shuts down. To fix this, you need to disconnect the main battery to reset the power control module. Dead battery in a locked car is a huge inconvenience, as you need power to open the trunk to access the battery, so it can lock you out of the car and it is nuisance to get it resolved. My suggestions: a) know emergency unlock procedure (with mechanical key hidden in the fob) and boost points in your engine bay b) avoid using OBD readers or assume it will glitch and reset PCM after each use. You can visually tell that the car did not fully power down if emergency triangle stays illuminated 10 minutes after you locked the car - this means PCM is glitched. More so, having marginal battery on these cars is known to trigger all kind of fault codes, so if you suddenly see multiple dash warnings about unrelated things... don't panic, it just might be a marginal battery.
While this is not a fault or mechanical issue, make sure to stay on top of transmission, differential, supercharger oil, brake fluids and engine coolant changes. Low miles on your car does not mean that original fluids are fine - as they degrade both with use and time. Unless you have records from PO, assume that nothing other than oil changes was done (many people treat lease cars as a rental). This means you have to catch up on all other fluid and filter changes. Changing engine oil is crucially important, but there are other fluids and filters that also have to be regularly changed. Especially important is transmission fluid and filter - these cars come equipped with a superb automatic transmission that I expect to last forever, that is unless you never change transmission fluid. With your 2015 car you are past-due for transmission service.
Also this has to be mentioned. If your car is still on Pzero tires - these are the worst "performance" tires in the industry. Upgrade to MP4S and it will transform how your car handles.
Old Dec 6, 2020 | 11:49 AM
Iandallas's Avatar
Thank you for being so detailed. I really appreciate it. I will keep all this in mind. My car had 2 previous lease owners. Currently sitting at 50k miles. Bought it from Jaguar/Land rover dealership and they informed a 80K service was completed already. Thankful of it since it has no warranty.
With the help of this forum and skrrrt garage on YT I know I'm in good hands to keep it in tip top shape.
Old Dec 6, 2020 | 11:52 AM
Iandallas's Avatar
No my in control apps did not have Waze or Google maps. And I'm now also seeing others talk about upgrades to the screen. Just watched a tutorial today on how to remove and add an adroid tablet on YT. I forget the name of it though.
Old Dec 6, 2020 | 02:09 PM
Carbuff2's Avatar
The other 'missing' things on the base model are 'dynamic' adjustable suspension and the dual-mode muffler that enables the loud exhaust noises.
I thought the "InControl App" capability was only on newer cars, began in '17 or '18s?
Old Dec 6, 2020 | 03:54 PM
glenno's Avatar
Love mine. Has all the options including the switchable exhaust. It's almost a crime that it doesn't have a lsd though. Any hot hatch will beat me away from the lights in cold or wet weather while I have a one wheel spin up. Once rolling though it's amazing. Just got the vap 416 tune.
Old Dec 6, 2020 | 07:44 PM
Iandallas's Avatar
Mine does have it but everything is super basic and ask me to upgrade to premium for some apps. I'm okay without it. I do wish I was able to use the Remote app though.
Old Dec 6, 2020 | 07:47 PM
Iandallas's Avatar
Really looks nice! And tell me more about the tune. Was it a long process?
Old Dec 7, 2020 | 11:16 AM
Mahjik's Avatar
https://www.velocityap.com/product/3...26-ecu-tuning/
Old Dec 7, 2020 | 12:24 PM
Iandallas's Avatar
Awesome! Thank you for sharing.
Old Dec 8, 2020 | 06:27 PM
bossman380's Avatar
May you send the link of recommended pages I'm looking at adding CarPlay to mine! Current one is no good...
I also just got an F-Type-S
Old Dec 8, 2020 | 08:33 PM
ancient's Avatar
I've had a 2015 Base V6 for about a year now. I felt the falling prices were making these cars a very compelling buy as I didn't want a boring SUV. And if this is my last petrol/gas car, well heck we might as well go out with a flourish. It's an amazing vehicle. I was lucky enough to find one with a few options so have the fancy adjustable seats, blind spot monitoring, adjustable exhaust, auto lights/beam/washers and the heated steering wheel. It does make it feel very comfortable and I still prefer the interior over most other models out there. It's just clean and functional and proportionate.
Been absolutely delighted with it, I drive it close to every day because it's just a fun car with a strangely unique vibe. I know it's anecdotal but I've personally had no issues with mine. I did upgrade to 20" wheels, put Continental Extreme Contact tires on it, and had all the brakes and pads replaced. Apart from that a regular service at the dealer (my local dealer is pretty decent) is all I do. The folks at the dealership tell me they feel JLR "nailed it" with the F Type as they rarely go wrong and as mentioned above the faults are pretty well known by now. I find the 340BHP engine PLENTY quick enough, if you use the manual shifter and drive in the 3k-5k sweet spot it goes like a rocket. But RIP your gas mileage lol. I did get the VAP pulley+tune but haven't installed yet, I'm kinda scared to do it lol.
Great car and I wouldn't hesitate to recommend the base model over the S or the R. The prices are good and you don't miss much over the pricier models, especially if you can find one with a few extras. But honestly the entire F Type range is special. Only downside I can say is that they ride fairly harsh, particularly with thinner sidewall tires and larger wheels. But as an owner sometimes you know you're trading comfort for looks and with this car who can blame you. It's one of the best looking cars in the world. I hope you enjoy every minute of it!
Old Dec 9, 2020 | 10:40 PM
Iandallas's Avatar
Sorry for the delay. The video above is what I used for in control Apps. And congrats on your new ride!
Old Dec 10, 2020 | 04:27 PM
andrew0068's Avatar
Some very, very useful information here
Old Sep 23, 2021 | 12:21 PM
LuvCOMPLEXbuilds's Avatar
Default Cure For The Stock "INFOTAINMENT" System
There is a company in the UK that makes an Android Auto & Apple Car Play Interface for our Beloved f-Types that plugs in directly behind the NAV Screen. Even has pre-amp outputs like a normal "Head unit".
Only downside is you must re-use your system's touch screen which is not as responsive as a "New" aftermarket unit would be.
Unique Auto Android Auto & Apple Car Play for Jaguar <==For their e-bay store. The Units they make can be bought on e-bay, However it is cheaper to order direct from their website. Just watch your currency converter very closely. It gets Confusing
or
(unique-a
d.co.uk) If their site ever comes back online from having maintenance done.
Old Sep 24, 2021 | 03:23 AM
nkc1989hkjc's Avatar
that's very beautiful! is that the sport design pack at the rear?? do you know the parts no. of that rear part?
many thanks!
Ric Rob
Jan 13, 2024 05:25 AM
Sleestak
Aug 17, 2022 11:22 AM
gmarand11
Aug 8, 2020 03:28 AM
wickeddtuna
Jul 7, 2020 03:10 PM
Tar1018
Feb 8, 2017 10:49 AM
