2017 f type back up light panel
Old Jun 12, 2016 | 04:41 PM
Black1's Avatar
Default 2017 f type back up light panel
Does anyone know how to remove the back light trunk panel on a 2017 f type?
Old Jun 12, 2016 | 06:43 PM
Unhingd's Avatar
A really great question! Hopefully doesn't require removing the rear bumper skin. I have to remove the front bumper skin on my MINI to replace the fog lamp bulbs. What a hassle.
Old Jun 12, 2016 | 06:46 PM
xdave's Avatar
I'm not sure which panel you mean? The internal carpet and plastic panels, or the bumper cover/valance? See attached PDFs for instructions.
If you just need to remove one/both reversing lamps you can do that from under the car (easier once you have removed the lower valance/diffuser, but it is not required). Note that the fog and reverse lamps are in the the same housing, which is why the workshop manual refers to them both as "rear fog lamps". The V6 for NAS markets uses a bulb, all other variants use LEDs.
Old Jun 12, 2016 | 06:57 PM
Unhingd's Avatar
xDave,
Here's the issue. Looking at the removal of the rear trim panels for the coupe, there are a number of fasteners coded in pink. Looking at the actual car, at those point there are small caps deeply recessed into the panel with no way to remove them to get access to whatever the fastener is. Any thoughts?
Old Jun 12, 2016 | 07:23 PM
xdave's Avatar
If you mean the ones in step 6, they are fir tree fastners. You just remove the visible bolts in the plastic trim and pull it hard towards you as if you are trying to rip it from the car. It will come off easily and I have not managed to break the clips in the at least half a dozen times I've had that trim out.
(Don't forget to remove the emergency release handle first, which requires you to push out a captive pin.)
Or do you mean a diferent picture?
Old Jun 12, 2016 | 07:55 PM
Unhingd's Avatar
No...that's it. I generally won't yank on things until I confirm that yanking is SOP. Thank you!
Old Jun 13, 2016 | 08:57 AM
xdave's Avatar
The only thing I will add is that it is very easy to drop fixings into the trunk void and have them roll under the battery or fuse boxes so it would be worth placing a blanket over everything before yanking it off just in case one/both of the clips fall out. I wish I had known that the first time I removed it - I had to remove the battery to get the captive pin from the release handle which rolled underneath it.
Old Jun 16, 2016 | 04:07 AM
ronniet's Avatar
thought according to the owners manual all you do is press on the light from the outside and turn to right or left then disconnect from rear
Old Jun 16, 2016 | 10:07 AM
Black1's Avatar
Hi Ronniet
Are those instructions for a 2017 F Type? If so can you send a picture of the instructions?
Thanks for the info.
Old Jun 16, 2016 | 10:13 AM
Unhingd's Avatar
For 2016, my owner's manual specifies:"All lamps are either LED or Xenon units and must only be replaced by a Dealer/Authorized Repairer"
Old Jun 17, 2016 | 01:55 AM
ronniet's Avatar
instructions for rear light ie those under the bumper line fog and reverse can be found if you go online and look up "jaguar topix" all the user manuals are there
Old Jun 17, 2016 | 09:05 AM
Black1's Avatar
Perfect Thank You!
Navyflyer
XJ40 ( XJ81 )
Apr 15, 2016 09:57 AM
Jandreu
Apr 14, 2016 02:32 PM
wa3ra
Apr 12, 2016 07:40 PM
hisport
Apr 3, 2016 07:34 PM
wforslund3
Mar 31, 2016 12:14 AM
