View Poll Results: Tire pressures?
37psi all around
100.00%
50psi in the front and 45psi in the rear
0%
Voters: 12. You may not vote on this poll
50psi in the front and 45psi in the rear?
Old Jul 27, 2024 | 10:38 PM
F-type-r-2022's Avatar
Default 50psi in the front and 45psi in the rear?
Hello guys,
I have always ran 37 psi all around on my 22 F Type R.
However, inside the dash it says:
Low speed: 37 all around
Normal: 50psi in the front and 45psi in the rear
Which one do you guys use for high performance street/freeway driving?
Thx
Old Jul 27, 2024 | 11:23 PM
CarlB's Avatar
32 lol
Old Jul 28, 2024 | 03:05 AM
scm's Avatar
scm
37 all round, though a bit higher after my independent has checked the pressures during a service.
Old Jul 28, 2024 | 03:13 AM
Also, Im thinking that the 50/45 is what Jag used to get the EPA results, since they call it the NORMAL inflation.🤔
Old Jul 28, 2024 | 04:25 AM
Robtrt8's Avatar
Old Jul 28, 2024 | 06:32 AM
DJS's Avatar
DJS
Mine calls for 36, I prefer 38.
Old Jul 28, 2024 | 08:27 AM
CJSJAG's Avatar
I think the high pressure (normal) is for high speed (testing the 170mph spec).
FWIW, the on board tire pressure sensor on my 2021 reads about 2 psi high.
I try to keep the tires at 38psi (vs 37psi spec).
Old Jul 29, 2024 | 04:48 AM
Default Update
Originally Posted by F-type-r-2022
Hello guys,
Thx
Owners manual say that 50/45 is for speeds over 176mph. It’s nice to know that, that speed is considered normal.😂
Old Jul 29, 2024 | 09:52 AM
CJSJAG's Avatar
But how do you inflate the tires harder while driving at a mere 170mph before hitting the magic number?
Old Jul 29, 2024 | 10:06 AM
When you notice the car losing stability, simply pull over and inflate your tires to 50/45.
Old Jul 29, 2024 | 02:07 PM
synthesis's Avatar
43psi x 4
Quadcammer
Nov 23, 2023 09:15 AM
W3IKE
Feb 19, 2023 01:43 AM
Al G
Dec 22, 2021 08:36 AM
jessiejames
XJ40 ( XJ81 )
Jan 10, 2014 07:58 AM
