Accessing the convertible storage area
Old Dec 23, 2023 | 04:59 PM
rsiddallr's Avatar
Default Accessing the convertible storage area
Through my F-Type convertible window I notices some leaves and other debris. How do I remove the windshield so that I can vacuum?
Old Dec 23, 2023 | 05:03 PM
DJS's Avatar
DJS
The wind deflector is removable. With the roof down, push down on the deflector, and pull the small latches out. Then it slides up. It’s still difficult to reach back there, as the roof has to be all (or partially) the way up!
Old Dec 24, 2023 | 07:37 AM
Carbuff2's Avatar
If your vacuum attachments won't reach, one strategy to remove leaves (once you get the wind barrier out of the way) is to wad a ball of masking tape on a stick or dowel. Use that to 'grab' the debris.
We needed to do that.
Old Dec 24, 2023 | 08:17 AM
rsiddallr's Avatar
Thanks. This is a great suggestion, especially since I have a Dyson stick vacuum. I will manually remove the large pieces and use your suggestion for the remainder.
Old Dec 24, 2023 | 08:22 AM
DJS's Avatar
DJS
Or flip the car over and shake it.
Old Dec 24, 2023 | 09:24 AM
Carbuff2's Avatar
Originally Posted by DJS
.... flip the car over and shake it.
But then, the debris ends up on the headliner.
If you put the top down FIRST, nothing will fall out.
(Just kidding around for Christmas)
Old Dec 24, 2023 | 01:17 PM
DJS's Avatar
DJS
I’m glad you pointed this out, so I won’t try it.
Klaus0401
Mar 24, 2025 10:02 PM
Jenise
Jun 14, 2022 10:24 AM
Rchuda
Jun 14, 2021 04:00 PM
CJSJAG
Apr 11, 2021 10:25 PM
brinny
Apr 5, 2020 09:47 AM
