Active Exhaust vs Dynamic Mode
Old Jun 29, 2018 | 09:08 AM
dcompain's Avatar
Default Active Exhaust vs Dynamic Mode
Do the sound notes from the exhaust system sound better when the car is in dynamic mode over than normal mode with the active exhaust switch engaged? I just purchased a 2015 F Type R and having had two base models before I can tell the significant sound difference between these models; however, and beyond, it sounds like on dynamic sound the sound is richer than on normal mode with the active exhaust engaged. Am I correct, or is it my old age is affecting my hearing?
Old Jun 29, 2018 | 09:49 AM
DJS's Avatar
DJS
I believe you're correct. I don't have switchable active exhaust (just plain active exhaust), but I've been running with the fuse pulled, so that the valves are open 100% of the time, Definitely louder/richer in dynamic mode, though I can't say I tried hard acceleration much when not in dynamic mode.
Old Jun 29, 2018 | 03:56 PM
Jagged Wire's Avatar
We need a sticky on this subject matter.
Old Jul 12, 2018 | 03:11 PM
Brandi Michelle's Avatar
I have to say that I notice a significant difference when in dynamic vs "normal" with AES on. Even more of a rich sound with more pops and crackles in sport
Old Jul 12, 2018 | 03:34 PM
NavyBlue's Avatar
+1
Old Jul 13, 2018 | 09:25 PM
bjg625's Avatar
Old May 4, 2019 | 07:34 PM
Terrance39's Avatar
Yeah definitely a difference.
Old May 5, 2019 | 10:13 AM
rexus31's Avatar
+4
Old May 5, 2019 | 09:46 PM
Tmb2283's Avatar
Why did you Pull the fuse?
I ask because I don't like how quiet my 2016 Manuel V6-S sounds at idle.
Would pulling the fuse make it sound louder?
Which fuse is it?
Does pulling the fuse effect anything else?
Old May 6, 2019 | 07:07 AM
Unhingd's Avatar
Which fuse is it?
Pulling fuse #43 only works on MY14 & 15 models (vacuum pump). No vacuum pump on later years. Also, the valves are always open at idle on the later models. (not enough vacuum to close the valves).
Old May 8, 2019 | 05:56 PM
16fnrbrg's Avatar
Definitely better sound, richer, deeper, and noticable.
carzaddict
Jan 17, 2025 02:56 AM
Simran Singh Randhawa
Dec 6, 2016 10:12 AM
bgreenstone
Feb 8, 2014 06:57 PM
ManMythLegend
Oct 13, 2013 11:05 AM
Jjprusk
Dec 13, 2011 09:51 AM
