Adding ambient lighting to F-type interior, input helpful
Old Aug 3, 2015 | 11:47 PM
TwiztOG43's Avatar
Originally Posted by EL1
Took some pics and it appears I have the light guides installed, just nothing lights up.
Center handle
Center handle underside
Door panel under handle latch
Yup, same as one, it's all there but nothing lights up
Old Aug 4, 2015 | 05:46 AM
Foosh's Avatar
So yours lights up but is there an Ambient controller in the LCD apps to turn them off or on? Mine doesn't have anything under extras except Stealth.
Did yours come from the dealer already functioning?
Thanks!
There are no controls for them, and they are blue only. They just light up when the headlights are on. They've been functioning since I took delivery in June 2014.
All I can verify is what's on the '14 MY base, and I checked again last night after your question. It's entirely possible they've been dropped off the base on '16s.
Old Aug 5, 2015 | 02:42 PM
EL1's Avatar
EL1
Thanx Foosh!
Am contacting my dealer to see if they can turn on. Will post results.
Cheers!
EL1
Old Aug 11, 2015 | 11:31 PM
EL1's Avatar
EL1
Question Ambient LED Update
So a quick update after going into 2 different dealerships. Both said they had no way of turning the ambient LEDs on for the base model if it doesn't offer the built-in App typically found in the Extras section.
So hopefully someone out there knows of a way to tap into the built-in LEDs somehow. Based on my earlier pics, the LEDs or at least the light pipes are installed. I'm assuming they're wired up for power or are ready to be... Even if they didn't have LEDs behind the light pipes/lenses, I'd be open to installing aftermarket LEDs behind them.
Anyone have any ideas?
Cheers,
EL1
Thanx Foosh!
Cheers!
EL1
Old Aug 11, 2015 | 11:59 PM
MagnumPI's Avatar
Well, if you can get me the circuit diagram, I can tell you how to put a switch in. Or, best case, they go somewhere obvious and it's a matter of removing a connector blank or something ridiculous. Or putting a connector on, something like that.
BrentGardner
29
Dec 16, 2024 12:13 AM
kenatofc
Oct 27, 2015 06:48 AM
mhamilton
Sep 15, 2015 05:13 PM
johanasu
Sep 3, 2015 12:39 PM
dpappyp
Aug 27, 2015 06:31 AM
