Alarm goes off when opening the boot
Old Aug 20, 2022 | 12:51 PM
Vindi's Avatar
Default Alarm goes off when opening the boot
Just recently the alarm has started going off when opening the hatchback from locked. Very strange, key is in my pocket and the fact that I can open the hatch says it is being recognized, I did change the fob battery just in case.
I have to reset the alarm by pushing the unlock button on the key fob.
Has anyone else had this happen, it has only just the last few days that this is happening and there are no other errors showing up.
Maybe I should reset via the battery disconnect method ?
Old Aug 22, 2022 | 02:04 AM
Scheffi's Avatar
I´ve had the same problem on my ´17 convertible. Jag swapped the lock of the boot and everything worked fine.
Old Aug 22, 2022 | 08:32 AM
SamtheSham's Avatar
Are you doing this while the car is locked?
Old Aug 23, 2022 | 01:20 AM
Scheffi's Avatar
Yes, but there´s no difference between opening the boot, or the doors. One of the locks had a failure and the alarm will go on.
Now i can open the car via the doors or the boot. No problems. I think the lock in the boot has a failure.
Maybe it is only a contact problem with one of the connectors. My car was in warranty, so i didn´t check this.
Old Aug 26, 2022 | 06:14 AM
Vindi's Avatar
The cars going in for service in a couple of weeks so I'll have the dealer check it out. It's still under warranty if anything needs replacing.
flying scotsman
Apr 28, 2023 08:10 AM
Defender99uk
Mar 12, 2022 12:04 PM
Jagcrew
Sep 29, 2021 01:48 PM
Andrew Harper
Oct 12, 2010 03:09 PM
