Another Tire Pressure sensor problem
Old Oct 28, 2018 | 01:03 PM
palmlakesman's Avatar
Default Another Tire Pressure sensor problem
Out for a drive to Cars and Coffee Palm Beach this morning, and my dash warning light showed all four tires low. I stopped to check and they were fine. Does anyone know how to reset/remove the warning light from the instrument panel? Is this something that only a dealer can do? BTW I just put on some Jag metal air caps on the valve stems, with the logo, could these be a problem?
BTW Cars and Coffee Palm Beach is amazing. They have well over a thousand cars, only one F Type today, mine. I find this hard to believe, as a lot of F Types are sold in South Florida.
Where are all you guys??
Old Oct 28, 2018 | 01:09 PM
scm's Avatar
scm
Face it, you're driving a very exclusive car!
Can't help with the TPMS, though, sorry. But you could change the valve caps back and see if the problem persists.
Old Oct 28, 2018 | 01:26 PM
Unhingd's Avatar
It is indeed likely, that it is the metal caps interfering with data transmission. My wife’s MINI suffered the same issue when fitted with metal caps.
Old Oct 28, 2018 | 01:38 PM
That sounds like a strong possibility. I took them off but the light remains. Is there any way to remove the annoying warning light?
A pic from this mornings cars and 'coffee.
Nice weather
Old Oct 28, 2018 | 09:25 PM
BritCars's Avatar
You should definitely take off the metal caps. They are usually made of a different metal than the stems and can corrode to them and cause them to break. Has been an issue on the XF and XJ
But I doubt that's causing the pressure error to come on. Are you sure the pressures are correct? When temp drops the pressure in the tyres drops and they will need more air. I would double check that first
Sometimes putting in extra pressure, driving for a bit then dropping it back down can help.
Otherwise it's a system error.
penguin
33
Dec 8, 2019 07:17 AM
rlembach
Aug 25, 2015 12:45 PM
Skid Mark
Feb 5, 2013 10:22 PM
dkeuper
Mar 20, 2011 12:09 PM
