ASR Exhaust Valve controller install guide
Was I. I swear, maybe I was stuck on dumb, but teh socket disconnect had me for over an hour and admittedly, I popped a little piece of plastic off the factory socket LOL.
BUT, its in and MAN, does it make a difference!
Fitted this kit - https://asr-component.com/Valve-Exha...V8/A-001-066-2
Remotes work well. Anyone had issues getting dynamic mode to remember last mode or fix to dynamic. Had some many attempts at trying either of the below methods, but no joy.
The start mode describes in which mode the device should start after the ignition is turned on. In the standard configuration, the device saves the last set mode (Last State).
The start mode can be freely programmed as desired:
Start Mode
- Last State: Press the button for "Sport Mode" 5 times within 5 seconds.
- Other Modes: Press the button for the mode you want to set as the start mode for about 10 seconds.
Start Mode
Worst case, my memory is that their technical support is pretty good. A quick reach out to ASR would no doubt go a long ways if nobody has an answer for ya…
I personally didn’t even explore this, as for my use case I want the default behaviour of it always remembering what I have it on.
mcphill
Mar 7, 2023 06:07 PM
