ASR Exhaust Valve controller install guide
Old Apr 11, 2026 | 04:21 AM
  #41
DMeister's Avatar
Originally Posted by rbzer
I wish @DMeister was in my garage right now! Geez
Lol, I gather you are doing the install now?
Old Apr 13, 2026 | 05:53 PM
  #42
rbzer's Avatar
Was I. I swear, maybe I was stuck on dumb, but teh socket disconnect had me for over an hour and admittedly, I popped a little piece of plastic off the factory socket LOL.
BUT, its in and MAN, does it make a difference!
Old Apr 23, 2026 | 03:30 PM
  #43
scz4's Avatar
Fitted this kit - https://asr-component.com/Valve-Exha...V8/A-001-066-2
Remotes work well. Anyone had issues getting dynamic mode to remember last mode or fix to dynamic. Had some many attempts at trying either of the below methods, but no joy.
Start Mode
The start mode describes in which mode the device should start after the ignition is turned on. In the standard configuration, the device saves the last set mode (Last State).
The start mode can be freely programmed as desired:
  • Last State: Press the button for "Sport Mode" 5 times within 5 seconds.
  • Other Modes: Press the button for the mode you want to set as the start mode for about 10 seconds.
The flaps will open and close 5 times to confirm the successful programming of the start mode.
Old Apr 23, 2026 | 04:20 PM
  #44
DMeister's Avatar
Start Mode
I personally didn’t even explore this, as for my use case I want the default behaviour of it always remembering what I have it on.
Worst case, my memory is that their technical support is pretty good. A quick reach out to ASR would no doubt go a long ways if nobody has an answer for ya…
Old Apr 23, 2026 | 04:27 PM
  #45
scz4's Avatar
Thanks, I've message them just after posting here. Will report back incase it helps anyone.
mitchyz250f
Jun 3, 2025 08:59 AM
87LC2
Jul 2, 2024 04:16 PM
mcphill
Mar 7, 2023 06:07 PM
ozguy
Sep 18, 2022 11:02 PM
MurrayG
Oct 17, 2019 11:24 AM
