Black Wheel Cleaner?
Old Jun 3, 2017 | 09:50 AM
AJF's Avatar
AJF
Default Black Wheel Cleaner?
I tried Adam's wheel cleaner and it left streaks. Anyone find a good one for black wheels?
Old Jun 3, 2017 | 09:59 AM
AJF's Avatar
AJF
Ah just found this thread, if anyone has anything to add tho I'd really like a concentrate that you dilute rather than buying bottles of Sonax
https://www.jaguarforums.com/forum/f...r-rims-179209/
Old Jun 3, 2017 | 03:57 PM
355rockit's Avatar
I just use Eco Touch waterless car wash. I buy concentrate and dilute. Works well and don't' have to worry about chemicals damaging wheel finish. You can get it on Amazon. Been using for past several years on all my cars. I haven't 'water washed' my car in months. I follow up with Maguire's Detailing spray.
Old Jun 3, 2017 | 09:51 PM
bjg625's Avatar
I use chemical guys waterless also but use Sonax on wheels, expensive but easy.
Old Jun 3, 2017 | 09:56 PM
Burt Gummer's Avatar
I switched from Iron-X to Sonax on black powercoated Gyrodynes.
Both are identical performance wise from what I can tell.
Iron-X stinks, Sonax does not, so Sonax wins.
Old Jun 4, 2017 | 08:28 AM
Greggbhill's Avatar
Consider coating wheels with something like opti-gloss to reduce brake dust baking on surface (my detailed suggested this and does seem to help). I used sonax and like it, am now using griot's heavy duty wheel cleaner - which doesn't smell, and sprays on sudsy. Either need to be rinsed off after a few minutes and then washed like regular paint. I also follow up with griot's best of show detailer using their blue pfm microfibre towel over whole car. Looks like new every time.
Old Jun 4, 2017 | 08:49 AM
Nati's Avatar
Sonax.
Pressure washer.
Master blaster.
Old Jun 4, 2017 | 11:28 AM
CRS 123's Avatar
How would you compare Griots to Sonax? I use and like Sonax Plus....but it's expensive.
CRS
Old Jun 4, 2017 | 12:19 PM
Greggbhill's Avatar
CRS
easier to fully coat as it is not as thick and can be sprayed instead of sloshed... sonax is thicker and I used to use more trying to fully coat. griots cant be left on as long or it dries streaky. Both need a high pressure wash to be touch less- I use garden hose (highest pressure stream) followed by detailer spray with PFM cloth. at the moment I prefer griots but both work well
