Boot / trunk drainage on convertible
Old 12-27-2015, 07:20 AM
OV14's Avatar
Default Boot / trunk drainage on convertible
The obvious downside of a convertible in the UK is the rain (especially at the moment).
However I noticed this morning on opening the boot lid that the tray / gulley which sits under the spoiler and has the windscreen washer fluid filler cap in it, was full of rain water. Has anyone else seen this happen?
It hadn't filled quite up to the level of the rubber boot seal but wasn't far off. Seems strange that this should fill with water and risk flooding the boot itself. Is there some drainage that is supposed to deal with this?
Old 12-27-2015, 08:19 AM
Foosh's Avatar
Received 1,026 Likes on 854 Posts
There are drains there. Check to make sure yours hasn't gotten clogged with dirt and debris.
Old 12-28-2015, 03:53 PM
Unhingd's Avatar
Received 4,652 Likes on 3,362 Posts
+1. Three drain holes in the deck behind the hatch seal:
Old 12-29-2015, 05:49 AM
OV14's Avatar
Thanks guys. Found it, was full of gunk and hard to spot. (Here is only the single drainage hole in the centre on mine).
Here's hoping the rain stops now.
Old 12-29-2015, 06:02 AM
Unhingd's Avatar
I'm curious whether the 3 holes are only found on the coupes, or whether they went to 3 holes on all later models after discovering the potential for clogging.
Old 12-29-2015, 08:49 AM
Greggbhill's Avatar
My 2016 vert only has 1 hole in center, but where the black plastic left/right edges meet metal, they seem to hover (as if to drain underneath). I can inspect closer and report back.
Old 12-30-2015, 03:13 PM
Foosh's Avatar
Same on the '14 convertible.
Old 12-30-2015, 04:18 PM
OV14's Avatar
Likewise. One central drainage point on my '14 UK convertible
Old 12-30-2015, 09:39 PM
Buckingham's Avatar
We only need one drainage hole since we don't drive our convertibles in the rain. We would get wet.
Old 12-31-2015, 04:16 PM
IRRBrogue's Avatar
My new '16 coupe has 3 holes. More water from the openings around the coupe deck lid?
Old 12-31-2015, 04:28 PM
Foosh's Avatar
Yep, that would be my guess. Convertible lid is flat, which doesn't channel water like the sloping coupe lid.
pod184
01-05-2022 09:58 AM
King Charles
09-13-2016 09:46 PM
magmedia
03-13-2016 10:38 AM
andypreston
E type ( XK-E )
02-21-2016 07:10 PM
Ubad2
12-25-2015 12:45 PM
Quick Reply: Boot / trunk drainage on convertible
